dejoro
Re: Ultimate UHD Drives Flashing Guide Updated 2024
Post by dejoro »
I have a Pioneer BDR-209D, firmware date 2014-12-05 . Is it possible to make it play in 4K... I have a big doubt, because reading this:
"Make sure your disc was manufactured after 2016 on label or end of 2015 if you want to take the risk."
Which player should I buy then? Pioneer? The Asus ASUS-BW-16D1HT?
Thanks for your answers
dejoro wrote: Fri Dec 06, 2024 10:35 am Hello,
You need to post your Makemkv info for your 209D drive to get help for UHD reading.
dejoro
Post by dejoro »
Excuse me, I forgot to give you this info:
Informations lecteur
Nom du lecteur SE : \Device\CdRom1
Profil actuel : BD-ROM
Fabricant : PIONEER
Produit : BD-RW BDR-209D
Révision : 1.30
Numéro de série : OCDL060556WL
Date micrologiciel : 2014-12-05
Marqueurs d'encryptage bus : 13
Version AACS la plus haute : 68
Drive platform: RS8600
Firmware version: 1.30/ID61
dejoro wrote: Fri Dec 06, 2024 11:10 am Excuse me, I forgot to give you this info:
Fabricant : PIONEER
Révision : 1.30
I‘ll send you a PM later today.
Fabricant : PIONEER
Révision : 1.30
PM sent.
0x1002
Post by 0x1002 »
Hello makemkv Community.
Ive registered to this Forum cause ive updated my BH16NS55 Firmware with the official LG Firmware Updater without knowing so much to what ive needed to do mkvs from UHD Disks to vesion 1.05.
So ive googled and found this nice place. Cause im a self-taught Person ive read all nessesary information.
First try flashing my BH16NS55 ended in error message. Ive read again and rechecked all and i found out that my 1.05 Firmware was encrypted.
So i needed to flash first to 1.05 Firmware from that mkv-firmware-pack and then downgrade to the 1.02.
Now all works. Nice works guys. keep going. Thumps up! :D
Keat1892
Post by Keat1892 »
I have an LG WH16NS40 that was working fine with 1.02 LibreDrive firmware. Then I found that mk-firmware-pack-20200720.zip had a 1.05 LibreDrive firmware and I thought "newer must be better, I'll get the LG bug fixes plus keep LibreDrive". Things seemed ok. I would occasionally get read errors, but chalked it up to invisible disc damage.
Recently, I pulled a disc out of the shrink wrap to rip it and got read errors. I reverted back to 1.02 firmware and the disc ripped fine. Lesson learned; bigger numbers are not always better. I should have listened to this guide and stayed with 1.02.
MrMegadeth99
Post by MrMegadeth99 »
What is the most recent guide for flashing a WH16NS40 drive? I haven't done it in several years and my old drive just died and purchased a new one.
Post by d00zah »
MrMegadeth99 wrote: Wed Dec 11, 2024 4:07 pm What is the most recent guide for flashing a WH16NS40 drive? I haven't done it in several years and my old drive just died and purchased a new one.
1st post of THIS very topic is routinely maintained & current. Replete w/ recommendations for FW for each drive, links to tools, instructions/videos & said FWs. A one stop shop...
Bigou
Post by Bigou »
Hello, the modified SDFtool Flasher you propose on the first page of this thread give a strange error message when I start it. "Object reference not set to an instance of an object."
After which I have a button to have more details which give wall of text, (Sorry, my computer being in French, part of the text is too. But I believe it doesn’t affect the relevant bits.) :
Consultez la fin de ce message pour plus de détails sur l'appel du débogage
juste-à-temps (JIT) à la place de cette boîte de dialogue.
************** Texte de l'exception **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at SDFtool_Flasher_Updated.Form1.Check_MakeMKV_Installation()
   at SDFtool_Flasher_Updated.Form1.Form1_Load(Object sender, EventArgs e)
   at System.Windows.Forms.Form.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
************** Assemblys chargés **************
System.Private.CoreLib
    Version de l'assembly : 6.0.0.0
    Version Win32 : Non applicable
    CodeBase :
    Version de l'assembly : 1.3.5.0
    CodeBase :
System.Runtime
    CodeBase :
    Version de l'assembly : 6.0.2.0
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
System.Drawing.Primitives
    CodeBase :
    CodeBase :
System.Drawing.Common
    CodeBase :
System.Threading
    CodeBase :
    CodeBase :
System.Collections
    CodeBase :
System.Diagnostics.Process
    CodeBase :
Microsoft.Win32.Primitives
    CodeBase :
    CodeBase :
System.Threading.Thread
    CodeBase :
Accessibility
    Version de l'assembly : 4.0.0.0
    CodeBase :
    CodeBase :
System.Numerics.Vectors
    CodeBase :
System.Memory
    CodeBase :
System.ComponentModel
    CodeBase :
System.Resources.Extensions
    CodeBase :
System.Drawing
    CodeBase :
System.ObjectModel
    CodeBase :
System.Linq
    CodeBase :
    CodeBase :
System.Collections.Concurrent
    CodeBase :
mscorlib
    CodeBase :
Microsoft.Win32.SystemEvents
    CodeBase :
System.Collections.NonGeneric
    CodeBase :
    CodeBase :
    CodeBase :
System.Private.Uri
    CodeBase :
    CodeBase :
    CodeBase :
System.Xml.ReaderWriter
    CodeBase :
System.Private.Xml
    CodeBase :
    CodeBase :
System.Net.WebClient
    CodeBase :
    CodeBase :
System.Xml.XmlSerializer
    CodeBase :
Microsoft.Win32.Registry
    CodeBase :
System.Runtime.Loader
    CodeBase :
System.Windows.Forms.resources
    CodeBase :
System.Diagnostics.StackTrace
    CodeBase :
System.Reflection.Metadata
    CodeBase :
System.Collections.Immutable
    CodeBase :
************** Débogage JIT **************
I can still click on Continue, but SDFtool Flasher is unable to see my Asus BW-16D1HT. (Or anything else, for that matter.)
— Bigou
Keat1892 wrote: Tue Dec 10, 2024 9:13 pm I have an LG WH16NS40 that was working fine with 1.02 LibreDrive firmware. Then I found that mk-firmware-pack-20200720.zip had a 1.05 LibreDrive firmware and I thought "newer must be better, I'll get the LG bug fixes plus keep LibreDrive". Things seemed ok. I would occasionally get read errors, but chalked it up to invisible disc damage.
WH16NS60 1.02 from that firmware pack is the recommended firmware for your drive and it fixes the sleep bug.
And no, generally newer is not better at all when it comes to drive firmware!
Post by d00zah »
Bigou wrote: Wed Dec 11, 2024 7:03 pm Hello, the modified SDFtool Flasher you propose on the first page of this thread give a strange error message when I start it. "Object reference not set to an instance of an object."
    CodeBase :
    CodeBase :
System.Runtime
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
System.Threading
    CodeBase :
    CodeBase :
System.Collections
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
Accessibility
    CodeBase :
    CodeBase :
    CodeBase :
System.Memory
    CodeBase :
    CodeBase :
    CodeBase :
System.Drawing
    CodeBase :
System.ObjectModel
    CodeBase :
System.Linq
    CodeBase :
    CodeBase :
    CodeBase :
mscorlib
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
System.Private.Uri
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
System.Private.Xml
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
Is MakeMKV installed (in the default location)? SDFtool Flasher is a front-end for the MakeMKV native flash utility. Met all the requirements detailed on the SDFtool Flasher page?
MrMegadeth99
d00zah wrote: Wed Dec 11, 2024 5:37 pm
I tired that for both encrypted and unencrypted and get error for both. My drive is WH16NS40. Can someone please tell me what I'm doing wrong?
MrMegadeth99 wrote: Thu Dec 12, 2024 12:56 pm
The firmware file name is usually much longer compared to what you typed. Did you rename it? Why don't you use SDFToolflasher?
viewtopic.php?f=16&t=22896
MrMegadeth99
I copied exactly what the guy in the YouTube video did and it. How do I use the SDFToolFlasher with this?
