Have both WH16NS40 + BH16NS40 with firmware version 1.02 + 1.03 respectively. Think the newest is version 1.05 however on the LG support page there are four versions of these drives so not sure which firmware to pick and if it would be worth while such as loosing features like I did on my Pioneer drive (long story ruined UHD support).
OS device name: F:
Product: BD-RE BH16NS40
Revision: 1.03
Serial number: [redacted]
Firmware date: 2114-03-26 11:15
Highest AACS version: 68
Drive platform: MT1939
Firmware version: 1.03
BD raw metadata read: Partial
OS device name: F:
Product: BD-RE WH16NS40
Revision: 1.02
Firmware date: 2114-05-07 10:26
Firmware version: 1.02
Worth updating firmware on the WH16NS40 to 1.05?
drknight71
Re: Worth updating firmware on the WH16NS40 to 1.05?
you already emailed me about this why waste my time in private then ask here anyway
not wort it to update them unless you want to brick them
so dont update them
so dont update them
drknight71
I didnt ask you about official manufacturer release made for that drive vs cross flash to unlock features. I was afraid if I upgrade the firmware to the last manufacturer release I would lose libredrive mode or direct access mode like I did on the Pioneer drive. I am sorry not trying to waste your time. Thought that others here would also have something to share and benefit from exchange of ideas. Please don't be offended. I did not mean to aggravate you here. Won't ask you in private from now on. Sorry.
The drive platform on both of those drives is listed as MT1939. As stated in the Ultimate UHD Drives Flashing Guide the drive platform needs to be MT1959 in order to flash them with firmware to enable LibreDrive and thus allow for UHD ripping. If you try to flash firmware designed for the MT1959 platform onto a MT1939 drive, you will brick the drive, rendering it useless.
If the drives are currently working for you for ripping DVDs and regular blu-rays, it is generally best to leave the firmware alone.
If you use the drives for things other than ripping discs with MakeMKV, well, then I doubt anyone here on the MakeMKV forums can speak to the usefulness of newer official firmware for whatever that task is.
DO NOT UPDATE THEM!!!!!drknight71 wrote: Fri Dec 06, 2024 1:25 am I didnt ask you about official manufacturer release made for that drive vs cross flash to unlock features. I was afraid if I upgrade the firmware to the last manufacturer release I would lose libredrive mode or direct access mode like I did on the Pioneer drive. I am sorry not trying to waste your time. Thought that others here would also have something to share and benefit from exchange of ideas. Please don't be offended. I did not mean to aggravate you here. Won't ask you in private from now on. Sorry.
You wont' be gaining anything and will lose LibreDrive mode but also LG seem to have messed up their official updater and drives that are MT1939 that get updated often end up bricked.
drknight71
Thanks Marty. I definitely will not. Thank you.
zaqqaz6917
Guess there will always be some who will not listen to experts and others with working experience and update firmwares to their own detriment
