Ultimate UHD Drives Flashing Guide Updated 2025
djshag
BENFEI SATA
#2551 Post by djshag » Wed Dec 04, 2024 6:11 pm
First, thanks for the helpful guide, tools, and firmware. I'm about to start digitizing several hundred Blu Ray/DVDs so we can pack up all the old discs, and this firmware should allow that process to go as smoothly as possible.
Second, I thought I'd chime in to confirm that the BENFEI SATA to USB 3.0 Cable, USB 3.0 to SATA III Hard Drive Adapter (the one with the 12V/2A Power Adapter) from Amazon worked great for flashing my new WH14NS40.
https://a.co/d/396HjXw
I saw some others reference this adapter within this thread, but since it isn't explicitly listed in the "USB enclosures/sata adapters that work with optical drives and flashing" section, and the Amazon posting only mentions CD/DVD I wanted to mention it again for anyone nervous about trying something not on that list.
And finally, I also thought it might be worth warning folks against purchasing the WAVLINK USB C to Dual Bay SATA Adapter,Hard Drive Convertor with 2 USB 3.0 Ports for External 3.5/2.5 Inch SSD HDD SATA III adapter from Amazon for use with an optical drive.
I initially picked up the WAVLINK adapter since it provides additional capabilities that could be useful down the line, but once I received it, I found that it doesn't seem to work with the WH14NS40 at all. With it connected, the computer doesn't even recognized there's a drive attached.
The WAVLINK, above, does work fine with some SATA SSDs without a problem, so I'm hanging on to it, but don't expect to buy one to use for reading/flashing an optical drive (at least not the WH14NS40).
-L
Re: BENFEI SATA
#2552 Post by dcoke22 » Thu Dec 05, 2024 5:47 am
I think the link is supposed to be to the one that doesn't work. However, it is to the one that works. Both links in your post link to the same thing. I don't know if that was your intention, but there it is.
dejoro
Re: Ultimate UHD Drives Flashing Guide Updated 2024
#2553 Post by dejoro » Fri Dec 06, 2024 10:35 am
I have a Pioneer BDR-209D, firmware date 2014-12-05 . Is it possible to make it play in 4K... I have a big doubt, because reading this:
"Make sure your disc was manufactured after 2016 on label or end of 2015 if you want to take the risk."
Which player should I buy then? Pioneer? The Asus ASUS-BW-16D1HT?
Thanks for your answers
#2554 Post by Coopervid » Fri Dec 06, 2024 10:37 am
You need to post your Makemkv info for your 209D drive to get help for UHD reading.
dejoro
#2555 Post by dejoro » Fri Dec 06, 2024 11:10 am
Excuse me, I forgot to give you this info:
Informations lecteur
Nom du lecteur SE : \Device\CdRom1
Profil actuel : BD-ROM
Fabricant : PIONEER
Produit : BD-RW BDR-209D
Révision : 1.30
Numéro de série : OCDL060556WL
Date micrologiciel : 2014-12-05
Marqueurs d'encryptage bus : 13
Version AACS la plus haute : 68
Drive platform: RS8600
Firmware version: 1.30/ID61
#2556 Post by Coopervid » Fri Dec 06, 2024 12:42 pm
Fabricant : PIONEER
Révision : 1.30
I‘ll send you a PM later today.
#2557 Post by Coopervid » Fri Dec 06, 2024 5:11 pm
Fabricant : PIONEER
Révision : 1.30
PM sent.
0x1002
#2558 Post by 0x1002 » Mon Dec 09, 2024 5:13 pm
Hello makemkv Community.
Ive registered to this Forum cause ive updated my BH16NS55 Firmware with the official LG Firmware Updater without knowing so much to what ive needed to do mkvs from UHD Disks to vesion 1.05.
So ive googled and found this nice place. Cause im a self-taught Person ive read all nessesary information.
First try flashing my BH16NS55 ended in error message. Ive read again and rechecked all and i found out that my 1.05 Firmware was encrypted.
So i needed to flash first to 1.05 Firmware from that mkv-firmware-pack and then downgrade to the 1.02.
Now all works. Nice works guys. keep going. Thumps up! :D
Keat1892
#2559 Post by Keat1892 » Tue Dec 10, 2024 9:13 pm
I have an LG WH16NS40 that was working fine with 1.02 LibreDrive firmware. Then I found that mk-firmware-pack-20200720.zip had a 1.05 LibreDrive firmware and I thought "newer must be better, I'll get the LG bug fixes plus keep LibreDrive". Things seemed ok. I would occasionally get read errors, but chalked it up to invisible disc damage.
Recently, I pulled a disc out of the shrink wrap to rip it and got read errors. I reverted back to 1.02 firmware and the disc ripped fine. Lesson learned; bigger numbers are not always better. I should have listened to this guide and stayed with 1.02.
MrMegadeth99
#2560 Post by MrMegadeth99 » Wed Dec 11, 2024 4:07 pm
What is the most recent guide for flashing a WH16NS40 drive? I haven't done it in several years and my old drive just died and purchased a new one.
#2561 Post by d00zah » Wed Dec 11, 2024 5:37 pm
1st post of THIS very topic is routinely maintained & current. Replete w/ recommendations for FW for each drive, links to tools, instructions/videos & said FWs. A one stop shop...
Bigou
#2562 Post by Bigou » Wed Dec 11, 2024 7:03 pm
Hello, the modified SDFtool Flasher you propose on the first page of this thread give a strange error message when I start it. "Object reference not set to an instance of an object."
After which I have a button to have more details which give wall of text, (Sorry, my computer being in French, part of the text is too. But I believe it doesn’t affect the relevant bits.) :
Consultez la fin de ce message pour plus de détails sur l'appel du débogage
juste-à-temps (JIT) à la place de cette boîte de dialogue.
************** Texte de l'exception **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at SDFtool_Flasher_Updated.Form1.Check_MakeMKV_Installation()
   at SDFtool_Flasher_Updated.Form1.Form1_Load(Object sender, EventArgs e)
   at System.Windows.Forms.Form.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
************** Assemblys chargés **************
System.Private.CoreLib
    Version de l'assembly : 6.0.0.0
    Version Win32 : Non applicable
    CodeBase :
    Version de l'assembly : 1.3.5.0
    CodeBase :
System.Runtime
    CodeBase :
    Version de l'assembly : 6.0.2.0
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
System.Drawing.Primitives
    CodeBase :
    CodeBase :
System.Drawing.Common
    CodeBase :
System.Threading
    CodeBase :
    CodeBase :
System.Collections
    CodeBase :
System.Diagnostics.Process
    CodeBase :
Microsoft.Win32.Primitives
    CodeBase :
    CodeBase :
System.Threading.Thread
    CodeBase :
Accessibility
    Version de l'assembly : 4.0.0.0
    CodeBase :
    CodeBase :
System.Numerics.Vectors
    CodeBase :
System.Memory
    CodeBase :
System.ComponentModel
    CodeBase :
System.Resources.Extensions
    CodeBase :
System.Drawing
    CodeBase :
System.ObjectModel
    CodeBase :
System.Linq
    CodeBase :
    CodeBase :
System.Collections.Concurrent
    CodeBase :
mscorlib
    CodeBase :
Microsoft.Win32.SystemEvents
    CodeBase :
System.Collections.NonGeneric
    CodeBase :
    CodeBase :
    CodeBase :
System.Private.Uri
    CodeBase :
    CodeBase :
    CodeBase :
System.Xml.ReaderWriter
    CodeBase :
System.Private.Xml
    CodeBase :
    CodeBase :
System.Net.WebClient
    CodeBase :
    CodeBase :
System.Xml.XmlSerializer
    CodeBase :
Microsoft.Win32.Registry
    CodeBase :
System.Runtime.Loader
    CodeBase :
System.Windows.Forms.resources
    CodeBase :
System.Diagnostics.StackTrace
    CodeBase :
System.Reflection.Metadata
    CodeBase :
System.Collections.Immutable
    CodeBase :
************** Débogage JIT **************
I can still click on Continue, but SDFtool Flasher is unable to see my Asus BW-16D1HT. (Or anything else, for that matter.)
Bigou
#2563 Post by MartyMcNuts » Wed Dec 11, 2024 9:10 pm
WH16NS60 1.02 from that firmware pack is the recommended firmware for your drive and it fixes the sleep bug.
And no, generally newer is not better at all when it comes to drive firmware!
#2564 Post by d00zah » Wed Dec 11, 2024 10:51 pm
    CodeBase :
    CodeBase :
System.Runtime
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
System.Threading
    CodeBase :
    CodeBase :
System.Collections
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
Accessibility
    CodeBase :
    CodeBase :
    CodeBase :
System.Memory
    CodeBase :
    CodeBase :
    CodeBase :
System.Drawing
    CodeBase :
System.ObjectModel
    CodeBase :
System.Linq
    CodeBase :
    CodeBase :
    CodeBase :
mscorlib
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
System.Private.Uri
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
System.Private.Xml
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
    CodeBase :
Is MakeMKV installed (in the default location)? SDFtool Flasher is a front-end for the MakeMKV native flash utility. Met all the requirements detailed on the SDFtool Flasher page?
MrMegadeth99
#2565 Post by MrMegadeth99 » Thu Dec 12, 2024 12:56 pm
I tired that for both encrypted and unencrypted and get error for both. My drive is WH16NS40. Can someone please tell me what I'm doing wrong?
