How good are Pioneer external drives
delio77
#1 Post by delio77 » Thu Dec 05, 2024 12:30 am
Good evening,
Looking at picking up a new Pioneer USB drive from Amazon. Was wondering how they stacked up to the more traditionally sized units in terms of compatibility, reliability and performance especially compared to the 5.25" big brothers.
Thanks in advance for any advice you can offer...
-Del
Re: How good are Pioneer external drives
#2 Post by dcoke22 » Thu Dec 05, 2024 1:40 am
Well, Pioneer drives are held in high regard on these forums. However, current Pioneer firmware can't be downgraded and is incompatible with LibreDrive, which means the drive's won't be able to rip UHDs.
Your best bet is buy one with older, compatible firmware from a seller in your region.
#3 Post by MartyMcNuts » Thu Dec 05, 2024 1:43 am
delio77 wrote: Thu Dec 05, 2024 12:30 am Good evening,
-Del
If you are wanting to rip UHD, then none of those from Amazon or any retail stores will be compatible as they all have newer firmware. The only external option from Amazon that works OOTB is the Verbatim 43888.
delio77
#4 Post by delio77 » Thu Dec 05, 2024 3:29 am
Oh I apologize...I thought the sticky mentioned that the Pioneers were now working. I totally misunderstood. I will look at the Verbatim, or just get a 5.25"
#5 Post by MartyMcNuts » Thu Dec 05, 2024 3:45 am
delio77 wrote: Thu Dec 05, 2024 3:29 am Oh I apologize...I thought the sticky mentioned that the Pioneers were now working. I totally misunderstood. I will look at the Verbatim, or just get a 5.25"
As I mentioned, most Pioneer models from Amazon and other stores are not compatible nor downgradable. The exceptions to this are:
Verbatim 43888: Official UHD drive that works OOTB
Verbatim 43890: Not a UHD drive but can currently be cross-flashed professionally (contact Billycar11)
Pioneer BDR-212V: Not a UHD drive but can currently be cross-flashed professionally (contact Billycar11)
All other Pioneer models cannot currently be made UHD or LibreDrive enabled as they have firmware that is too new (Post Dec 2022).
If you would prefer a model other than those listed above, check with a seller on this forum (including myself). We do have some Pioneer drives available that are LibreDrive enabled and UHD compatible.
delio77
#6 Post by delio77 » Thu Dec 05, 2024 3:49 am
Thanks Marty,
I wasn't debating you, I was clearly mistaken and acknowledged that. Sorry again!
I am interested in purchasing a prepared solution.I will PM you and/or Billy. His stock seems to be low at the moment
delio77
#7 Post by delio77 » Thu Dec 05, 2024 3:55 am
Marty I am not sure if my PM made it to you, but I am interested
#8 Post by MartyMcNuts » Thu Dec 05, 2024 4:16 am
delio77 wrote: Thu Dec 05, 2024 3:55 am Marty I am not sure if my PM made it to you, but I am interested
Replied to your PM.
#9 Post by dcoke22 » Thu Dec 05, 2024 5:40 am
There was a period of time after MakeMKV added support for Pioneer drives and before Pioneer updated their firmware to disable UHD ripping where you could buy one of the correct Pioneer drives from your favorite retailer and it would work right out of the box. Unfortunately, those days have passed.
Jack_The_Ripper
#10 Post by Jack_The_Ripper » Sun Dec 08, 2024 9:35 pm
I've recently acquired a Pioneer BDR-S13U-X 5.25 SATA drive from Billycar11 to begin the journey of digitizing my library and I must say, I'm quite impressed. No issues whatsoever and the drive is exceptional quality. To give you an idea of how quiet it is, while ripping I had to put my ear to it to make sure it was running - and the drive is in a room that is acoustically treated. I can't recommend the BDR-S13U-X 5.25 enough. Same with Billy.
