Errors with Brand New Dark Knight Rises 4K
rimmi2002
Post by rimmi2002 »
Hi I just bought the 4K Dark Knight Trilogy from Gruv. 2/3 disc ripped fine. Third (Batman Rises) gave me the following errors. Some on reading titles and then rest on ripping. Stops ~20gbs in. Have cleaned the disc. Can't see any scratches. Is this just a bad disc? I have tried 4 times, cleaning the disc thoroughly. No luck.
My Drive is Pioneer BDR212 with patched firmware. It has ripped the other two discs fine from this pack and 7/7 on other UHDs so far. Missed one cause couldn't find decryptions keys. I emailed in the log file for that. Hoping that gets sorted out.
MakeMKV v1.17.8 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\rsmom/MakeMKV_log.txt
Using LibreDrive mode (v01.0 id=F1ED73020654)
DEBUG: Code 100865282 at e2ZHo%(J'4phL9N]&.:121263429
DEBUG: Code 100865282 at e2ZHo%(J'4phL9N]&.:121262302
Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading 'BD-RE PIONEER BD-RW BDR-S12U 1.02 DDDL027331WL' at offset '33422311424'
DEBUG: Code 100942878 at e2ZHo%(J'4phL9N]&.:121263429
DEBUG: Code 100942878 at e2ZHo%(J'4phL9N]&.:121262302
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading 'BD-RE PIONEER BD-RW BDR-S12U 1.02 DDDL027331WL' at offset '33422311424'
Title #00002.mpls has length of 84 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00009.mpls has length of 341 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00010.mpls has length of 31 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00011.mpls has length of 51 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00032.mpls has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
File 00033.mpls was added as title #0
Title #00036.mpls has length of 60 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title 00020.mpls is equal to title 00033.mpls and was skipped
Title 00034.mpls is equal to title 00033.mpls and was skipped
Title #00000.m2ts has length of 15 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00002.m2ts has length of 84 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00004.m2ts has length of 9 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00005.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00006.m2ts has length of 17 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00007.m2ts has length of 23 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00008.m2ts has length of 341 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00009.m2ts has length of 31 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00010.m2ts has length of 51 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00012.m2ts has length of 6 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00016.m2ts has length of 8 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00021.m2ts has length of 6 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00026.m2ts has length of 11 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00029.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00031.m2ts has length of 60 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Saving 1 titles into directory //nuc/
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00030.m2ts' at offset '30162548736'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '30162548736'
DEBUG: Code 3221225628 at e2ZHo%(J'4phL9N]&.:213131502
DEBUG: Code 100864261 at e2ZHo%(J'4phL9N]&.:213131502
DEBUG: Code 0 at MUklj]%J8Q@ \s=`g8hm:29395793
DEBUG: Code 0 at >{`y(>CqW-`Fca0ypbVz:29394068
DEBUG: Code 0 at MUklj]%J8Q@ \s=`g8hm:213131157
DEBUG: Code 0 at MUklj]%J8Q@ \s=`g8hm:121262647
DEBUG: Code 14727807 at MUklj]%J8Q@ \s=`g8hm:121261773
DEBUG: Code 0 at r*4xP~>k4SvZ3d8pxZ:2I:121268972
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 0 to file //intel-nuc/Intel-NUC Downloads/01. Movies/Dark
nick.campbellbro
Re: Errors with Brand New Dark Knight Rises 4K
Post by nick.campbellbro »
I had a similar problem to that with the same disk. I bought the box set and the first two worked perfectly with my LG BH16NS55, but then DKR would get stuck ripping due to Hashcheck errors. It let me backup the disk, still with errors, and then when you played the backup, there were bits where the picture and sound broke up. I bought a Pioneer Pioneer BDR-UD04 from a seller listed on this forum and that ripped without any errors and it plays perfectly.
rimmi2002 wrote: Thu Dec 05, 2024 1:58 am Hi I just bought the 4K Dark Knight Trilogy from Gruv. 2/3 disc ripped fine. Third (Batman Rises) gave me the following errors. Some on reading titles and then rest on ripping. Stops ~20gbs in. Have cleaned the disc. Can't see any scratches. Is this just a bad disc? I have tried 4 times, cleaning the disc thoroughly. No luck.
If cleaning doesn't help, either try a different drive or replace the disc/set.
