PM sent.robi0026 wrote: Wed Dec 04, 2024 4:24 am @Coopervid, can I get firmware as well?
Drive Information OS device name: G: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 77 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
LibreDrive for Pioneer drives
bub_b_les
Please send me too.
Revision: 1.14
Serial number: [redacted]
Highest AACS version: 81
Revision: 1.14
PM sent.bub_b_les wrote: Fri Dec 06, 2024 4:26 am Please send me too.
Revision: 1.14
leaflet
Please send me too. Thanks.
OS device name: H:
Product: BD-RW BDR-TD05
Revision: 1.01
Serial number: MEXXXXXXXXXX
Firmware date: 2013-04-09
Drive platform: RS8211
Firmware name: PIONEER BDR-TD05
Firmware version: 1.01
OS device name: H:
Revision: 1.01
I don't think that this drive can be flashed to be UHD compatible.leaflet wrote: Sun Dec 08, 2024 7:31 am Please send me too. Thanks.
OS device name: H:
Revision: 1.01
leaflet
I saw these two lines in the list within the first post of this thread.Coopervid wrote: Tue Dec 10, 2024 10:13 amI don't think that this drive can be flashed to be UHD compatible.leaflet wrote: Sun Dec 08, 2024 7:31 am
Revision: 1.01
PIONEER-BD-RW___BDR-TD05-1.00-DCD80C11-8211ID01-20120713
PIONEER-BD-RW___BDR-TD05-1.02-F9240B3B-8211-20140619
What does that mean?
It means that your drive is Libredrive compatible. It doesn't mean your drive can be made UHD compatible.leaflet wrote: Tue Dec 10, 2024 10:34 amI saw these two lines in the list within the first post of this thread.Coopervid wrote: Tue Dec 10, 2024 10:13 amI don't think that this drive can be flashed to be UHD compatible.leaflet wrote: Sun Dec 08, 2024 7:31 am
Revision: 1.01
leaflet
Got it. Thanks.Coopervid wrote: Tue Dec 10, 2024 1:49 pmIt means that your drive is Libredrive compatible. It doesn't mean your drive can be made UHD compatible.leaflet wrote: Tue Dec 10, 2024 10:34 amI saw these two lines in the list within the first post of this thread.Coopervid wrote: Tue Dec 10, 2024 10:13 am
jayude
Re: Pioneer BDR-XD08UMB-S w/1.04 FW
I'd be interested in some older firmware ones, I don't know how to contact you though.Billycar11 wrote: Mon Dec 02, 2024 4:41 amyeah sorry man that wont work i would return it if you can i sill have pioneers with old fw if you want onejohn_galt wrote: Mon Dec 02, 2024 4:04 am
Ok. Here you go. From the posts, it sounds like I am screwed until a miracle happens? Been using this model for awhile, but new one not working. Appreciate all the work you guys are doing:
OS device name: /dev/sr0
Product: BD-RW BDR-XD08U
Revision: 1.04
Firmware date: 2024-10-09
Drive platform: Pioneer RS9331
Firmware version: ID05
email in my signature belowjayude wrote: Wed Dec 11, 2024 1:58 am
bodivijay1985
Dear Experts,
Please help me to enable LibreDrive in the following drive,
OS device name: F:
Current profile: BD-R SRM
Product: BD-RW BDR-XS08U
Revision: 1.00
Serial number: BLDLXXXXXXJP
Firmware date: 2022-10-11
Highest AACS version: 61
Drive platform: Pioneer RS9621
Firmware version: ID69
Thank you,
Bodivijay1985
OS device name: F:
Revision: 1.00
Thank you,
Bodivijay1985
Read this.bodivijay1985 wrote: Wed Dec 11, 2024 8:50 pm Dear Experts,
OS device name: F:
Revision: 1.00
Thank you,
Bodivijay1985
viewtopic.php?f=19&t=30383&p=164008&hilit=XS08U#p164008
bodivijay1985
Hi Coopervid,
Thank you.
I went through the post.
I send a private message to mike admin. However, the message is still in outbox.
I dont know how to contact him.
Appreciate, if you can help me to contact him.
Thank you.
No, I don't have any other idea. Please try Woodstock. He might have better channels.bodivijay1985 wrote: Sat Dec 14, 2024 6:36 pm Hi Coopervid,
Thank you.
And I don't either - Mike shows up in the forum every couple of months to update the beta key, but other than that, it's random. I've had a private message queued up for him since the beginning of October that he hasn't read yet.Coopervid wrote: Sat Dec 14, 2024 6:51 pm No, I don't have any other idea. Please try Woodstock. He might have better channels.
