Hey!
I have already ripped episode 1 flawlessly from this disc and episode 3 on a second attempt but I can't get episode 2 to work. (Episode 3 has gone back to not working) (Episode 1 still works without problems)
I have cleaned the disc with a clean microfiber cloth and used a lens cleaner as recommended on other posts.
I've tried version 1.17.8 and 1.17.7 of MakeMKV.
Here's the error it spits out: (Sorry for the Danish!)
Sikkerhedskopierer skiven til mappe "D:/Media/Movies/backup/GOTUHD_S5_D1_B5"
Indlæst indholds-kontrolsumtabel, godkender integriteten af M2TS-filer.
Fejl 'SCSI-fejl - ILLEGAL REQUEST:INVALID FIELD IN CDB' under læsning af '/BDMV/STREAM/00051.m2ts' ved offset '6328811520'
Det lykkedes ikke at gemme titel /BDMV/STREAM/00051.m2ts til fil D:/Media/Movies/backup/GOTUHD_S5_D1_B5/BDMV/STREAM/00051.m2ts
Fejl 'SCSI-fejl - ILLEGAL REQUEST:INVALID FIELD IN CDB' under læsning af '/BDMV/STREAM/00062.m2ts' ved offset '0'
Det lykkedes ikke at gemme titel /BDMV/STREAM/00062.m2ts til fil D:/Media/Movies/backup/GOTUHD_S5_D1_B5/BDMV/STREAM/00062.m2ts
Sikkerhedskopiering klar, men 2 filer fejlede kontrolsumtjek
Anvender LibreDrive-tilstand (v06.3 id=0FA242DD4D0B)
Fejl 'SCSI-fejl - ILLEGAL REQUEST:INVALID FIELD IN CDB' under læsning af '/BDMV/STREAM/00051.m2ts' ved offset '6334181376'
/BDMV/STREAM/00051.m2ts is episode 2.
Is my drive dying or is the disc just broken? (I've been getting these errors on quite alot of the discs so far, tho all have been resolved with a little extra cleaning using only a microfiber cloth)
Problems with Game of thrones Season 5 Disc 1.
Re: Problems with Game of thrones Season 5 Disc 1.
It is probably just the disc. In my experience, some drives just don't like some discs.
Yep, GoT and LotR boxsets are notoriously bad quality discs. There are tons of posts about them. Either try a different drive or replace the disc/set if you can.Melten wrote: Wed Dec 04, 2024 5:09 pm Hey!
Melten
Ahh, thanks.
I did receive the box set with alot of scratches from the manufacturer so that did seem likely
(No shipping damage, just scratches on the casings)
I believe a local ministore has Game of Thrones atm so I'll figure something out.
Thank you for the confirmation!
