BDR 212V UHD Guide
squatch316
BDR 212V UHD Guide
#1 Post by squatch316 » Sun May 19, 2024 10:46 pm
Hello, New to this but i've been using this 212v to backup my normal blu-rays for about a year now and just went to try a few of my 4k discs and its showing no disc inserted. Here is drive info and what makemkv says
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.00
Serial number: [redacted]
Firmware date: 2020-08-07
Bus encryption flags: 13
Highest AACS version: 58
Drive platform: RS8F00
Firmware version: 1.00/ID06
TIA
Re: BDR 212V UHD Guide
#2 Post by Coopervid » Sun May 19, 2024 11:16 pm
squatch316 wrote: Sun May 19, 2024 10:46 pm Hello, New to this but i've been using this 212v to backup my normal blu-rays for about a year now and just went to try a few of my 4k discs and its showing no disc inserted. Here is drive info and what makemkv says
Revision: 1.00
TIA
Read your PM.
MattiKiwi
#3 Post by MattiKiwi » Wed Dec 04, 2024 2:21 pm
Could you PM me as well I have the same issue (drive has been flashed)
#4 Post by Coopervid » Wed Dec 04, 2024 7:13 pm
MattiKiwi wrote: Wed Dec 04, 2024 2:21 pm Could you PM me as well I have the same issue (drive has been flashed)
Your drive NEEDS to be flashed. Read your PM.
MattiKiwi
#5 Post by MattiKiwi » Wed Dec 04, 2024 8:10 pm
But my drive has been successfully flashed, I can't read any DVD or Blu Ray, I tried tweaking the minimum lenght duration and it didn't help either...
MattiKiwi
#6 Post by MattiKiwi » Wed Dec 04, 2024 10:42 pm
So I reverted back to 1.02, is there no way to make the driver work ? I can't read any disc, it says no disc is inserted no matter what...
drknight71
#7 Post by drknight71 » Thu Dec 05, 2024 12:33 am
See that the drive is on sale on Amazon: https://www.amazon.com/Pioneer-BDR-212V ... =8-13&th=1
Worth buying?
fhalperformance
#8 Post by fhalperformance » Thu Dec 05, 2024 12:37 am
Coopervid wrote: Sun May 19, 2024 11:16 pm
Revision: 1.00
TIA
Read your PM.
I just bought it from the link. Can you send me the instructions as well?
#9 Post by Coopervid » Thu Dec 05, 2024 10:18 am
fhalperformance wrote: Thu Dec 05, 2024 12:37 am
Revision: 1.00
TIA
Read your PM.
PM sent.
Rinzler
#10 Post by Rinzler » Thu Dec 05, 2024 7:49 pm
Hi @Coopervid,
Heard you’re the person for getting a Pioneer BDR-212V to read UHD’s. Could you please send me a PM?
I also have a BDR-UD03, will the same firmware work for both? Thanks!
OS device name: F:
Revision: 1.02
Serial Number: [redacted]
Firmware date: 2022-05-31
Highest AACS version: 63
Firmware version: ID06
Product: BD-RW BDR-UD03
Revision: 1.14
Firmware date: 2020-06-15
Highest AACS version: 70
Drive platform: RS8511
Firmware version: 1.14
#11 Post by Coopervid » Fri Dec 06, 2024 10:19 am
Rinzler wrote: Thu Dec 05, 2024 7:49 pm Hi @Coopervid,
OS device name: F:
Revision: 1.02
Revision: 1.14
PM sent.
raf_finals
#12 Post by raf_finals » Sat Dec 07, 2024 6:54 am
Hello @Coopervid,
Could you please help me flash my BDR-212V to read UHD?
Here is my drive info:
Revision: 1.02
Highest AACS version: 44
Best Regards
Keat1892
#13 Post by Keat1892 » Tue Dec 10, 2024 5:40 am
@Coopervid,
Please PM the LibreDrive instructions.
OS device name: H:
Revision: 1.02
Serial number: <...>
Highest AACS version: 81
#14 Post by Coopervid » Wed Dec 11, 2024 5:19 pm
raf_finals wrote: Sat Dec 07, 2024 6:54 am Hello @Coopervid,
Revision: 1.02
Best Regards
PM is coming.
#15 Post by Coopervid » Wed Dec 11, 2024 5:20 pm
Keat1892 wrote: Tue Dec 10, 2024 5:40 am @Coopervid,
OS device name: H:
Revision: 1.02
PM is coming. You new guys need to know: I will delete PMs after they are not read within 14 days!!!
