flojo
#1
Post
by flojo » Fri Nov 08, 2024 1:12 am
I don't understand why, but running the below command seems to hang infinitely without ever printing anything to stdout other than 2 new lines. It doesn't flash anything. I do have sg3-utils installed but do I need others?
test@test:~/test$ makemkvcon f -l
Found 1 drives(s)
00: dev_21:5, /dev/sr0, /dev/sr0
ASUS_BW-16D1HT_3.10_211901041014_KL5L92D1732
test@test:~/test$ sudo makemkvcon f -d 'dev_21:5' -f ./sdf.bin rawflash main -i ./firmware.bin
_(cursor here)
I am trying to flash the "
hacked version of the 3.10 firmware" firmware found at:
http://wiki.redump.org/index.php?title= ... T_firmware It might be the same as the one from the firmware pack found here with the exception of that edit for not using the cache when reading the lead out.
#2
Post
by d00zah » Fri Nov 08, 2024 1:46 am
It's helpful to copy/paste the current MakeMKV Drive Info/LibreDrive Info so we have a reliable starting point.
flojo
#3
Post
by flojo » Fri Nov 08, 2024 3:00 am
It is as far as I know currently flashed with the firmware found in the all-in-one pack found here, which I think is "ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin".
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KL5L92D1732
Bus encryption flags: 1F
Highest AACS version: 72
Firmware version: 3.10
#4
Post
by d00zah » Fri Nov 08, 2024 3:47 am
I don't see anything obvious. How is the drive attached? Does MakeMKV function, as is?
flojo
#5
Post
by flojo » Fri Nov 08, 2024 11:29 am
I downloaded and used the 1.17.7 binary and the same command worked. I'm not sure if it's something with the newest version along with the drive or if something is wrong with the latest "make install" or ... ?
FWIW, it is a USB 2.0 controller and using lsusb -v:
idVendor 0x1bcf Sunplus Innovation Technology Inc.
idProduct 0x0c31 SPIF30x Serial-ATA bridge
Also that patched firmware from redump.org is seemingly the same Libre firmware.
#6
Post
by Coopervid » Fri Nov 08, 2024 11:47 am
What are you trying to achieve as the drive is already Libredrive enabled?
Not all USB-SATA bridges support flashing.
flojo
#7
Post
by flojo » Fri Nov 08, 2024 1:04 pm
TLDR; 1.17.8 failed, 1.17.7 worked.
I wanted to achieve what it states on that redump page regarding reading the CD lead-out.
To be clear, I was using the above USB controller and makemkv version 1.17.8 that I installed via "make install" (both the "oss" and "bin" packages). It did not flash, it hung without printing anything, not even the boilerplate version line that ends with "started". However, makemkvcon and the GUI still worked fine to rip UHD, so the problem seemed specific to the flashing feature.
The flashing worked when I downloaded the 1.17.7 binary and ran it with the command sudo ./makemvcon f -d 'dev.... the exact same options.
#8
Post
by d00zah » Fri Nov 08, 2024 1:09 pm
flojo wrote: ↑Fri Nov 08, 2024 1:04 pm
Cmd line looked good, so my line of questioning was largely to narrow the field of typical culprits. Glad you got it going.
ethanj
#9
Post
by ethanj » Tue Nov 19, 2024 2:25 am
Same issue here on MakeMKV 1.17.8 and SDF.bin 0x98.
Adding the verbose flag prints "Loaded SDF.bin version 0x98" before 2 blank lines, then hangs.
Will try 1.17.7...
ds6477
#10
Post
by ds6477 » Wed Dec 04, 2024 1:53 am
I just had a similar experience trying to flash an Archgon slim drive from 1.03 to 1.00 (suggested
here in order to be able to read UHD discs on linux). I originally flashed the drive to 1.03 using the SDFTool and the "all you need firmware pack" linked on the "Ultimate UHD Drives Flashing Guide" post. The drive worked well on the windows machine. I have now moved the drive over to linux and only just discovered the UHD read issue.
Using makemkvcon from 1.17.8 failed in the same manner as the original post (two blank lines, the drive wasn't flashed), whereas hopping over to 1.17.7 worked right away. makemkvcon now reports the firmware version as being 1.00. I used the same sdf.bin in both attempts.
Infidelus
#11
Post
by Infidelus » Fri Jan 31, 2025 12:33 pm
Thanks for this. I have just spent far longer than I should have needed trying to flash my new ASUS drive and wondering why all I got was a blank screen. Downgrading to 1.17.7 was the fix
. 1.17.8 does not work for flashing.
olep65
#12
Post
by olep65 » Wed Feb 05, 2025 1:39 pm
I installed the new version V1.17.9 and ran into the same problem.... I was hoping the new one would correct the issue but apparently not.
Solved by again deleting the program, installing the last version that was working, so v1.17.7, then it works.
I run on Ubuntu 24.04,
Drives:
LG HL-DT-ST_BD-RE__BH10LS30
Asus BW-16D1HT
mayorun
#13
Post
by mayorun » Thu Feb 20, 2025 9:08 pm
I wish I had found this thread before I've tried for over two hours with version 1.7.9. But thanks for telling here, I wouldn't had thought of that! Compiled version v1.7.7, worked like a charm.
