Player slows down when trying to rip files all at once or more than one
Blaze
Post by Blaze »
Been trying to Rip a Blue Ray of the My-Hime anime series, disk loads fine and I see everything but when I either try to rip either every episode on it or more than 2 its starts up fine but then the blue light of my Asus disk player stops blinking after a few seconds and it slows down to be very slow in Ripping.
Ripping it one at a time works but I would like to do more than one at a time if possible
Re: Player slows down when trying to rip files all at once or more than one
Blaze wrote: Tue Dec 03, 2024 11:39 pm Been trying to Rip a Blue Ray of the My-Hime anime series, disk loads fine and I see everything but when I either try to rip either every episode on it or more than 2 its starts up fine but then the blue light of my Asus disk player stops blinking after a few seconds and it slows down to be very slow in Ripping.
Did you try creating a folder backup of the disc first? Then open the folder backup and rip all of the files.
Blaze
Post by Blaze »
Tried doing that but problem still happens. Stopped and turned what was 28 minutes into 5 hours and increasing.
