Accessing my external drives
nypaulie
#1 Post by nypaulie » Tue Dec 03, 2024 5:40 pm
I have a collection of movies in .iso form. Because they are large files I keep them on an external hard drive. I know how to use Makemkv to turn them into .mkv files. My problem is locating them. How do I locate them using the file finder icon? The drives don’t show up like they do from my Linux file finder app.
Re: Accessing my external drives
#2 Post by Woodstock » Tue Dec 03, 2024 6:29 pm
Is there a reason why you don't extract the movie files from them, and name them with the name of the movie? That's generally the reason for using an app like MakeMKV...
bmillham
#3 Post by bmillham » Tue Dec 03, 2024 8:42 pm
You need to select Computer and then go to where the drives are mounted (probably /media or /mnt).
nypaulie
#4 Post by nypaulie » Fri Dec 06, 2024 4:49 pm
You wrote: “ You need to select Computer and then go to where the drives are mounted (probably /media or /mnt).”.
That’s what I’m trying, but the drives do not show up, unlike they do when I’m simply using a file finder. Maybe my version of Makemkv needs some tweaking whatever that might be.
bmillham
#5 Post by bmillham » Mon Dec 09, 2024 5:48 am
Are you using a snap or flatpak? If so then you probably need to give it permission to access the drives.
