Flashing Firmware makemkvcon hangs, does nothing
RippidyDooDa
#1 Post by RippidyDooDa » Tue Dec 03, 2024 7:55 am
Hey all, I can't seem to find an answer to this so trying a new post.
I followed all of the directions for flashing firmware. I've got a WH16NS50 manufactured in July 2024.
This is the command I'm running...
sudo makemkvcon f -d /dev/sr0 -f /home/luke/Downloads/sdf.bin rawflash enc -i /home/luke/Downloads/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
After hitting enter it just hangs. Nothing happens. I've tried with/without sudo, with/without enc, etc., but nothing is happening.
Any pointers?
flojo
Re: Flashing Firmware makemkvcon hangs, does nothing
#2 Post by flojo » Tue Dec 03, 2024 4:34 pm
It'd bugged. Try a version prior. Old trial versions don't rip but they seem to still flash.
av8orbysea
#3 Post by av8orbysea » Tue Dec 03, 2024 4:54 pm
Had a similar experience myself. I ended up flashing on another machine...actually my laptop...which was pretty straight forward. Then I reconnected the drive to my Plex server (Ubuntu).
FWIW... I've found makemkvcon on the command line in Ubuntu (22.04 LTS) to be occasionally unstable (for flashing and ripping). What worked better for me was installing through snap on Gnome (after installing the graphical environment) which has worked perfectly so far. Makemkvconf hung in some places while accessing the drive without any log output to explain why. I believe, though, that the snap version is one version behind the command line...perhaps there is something to that. Would fit in to what flojo said previously.
...K
spkbd
#4 Post by spkbd » Wed Jan 15, 2025 12:26 am
I just ran into this issue myself and resolved it by reverting to 1.17.6 that allowed me to flash the drive. I used the flatpak installer, so it is quite easy to install a prior version
List available versions
flatpak remote-info --log flathub com.makemkv.MakeMKV
Revert to 1.17.6
flatpak update --commit=01cd43d6aed487b21bc714a1541c17076bbf67113b677f5845ec9ffde8cfc988 com.makemkv.MakeMKV
Hope this helps, good luck with your endeavors
