DUMP Submitted Mandalorian S3
#1 Post by SamuriHL » Sun Dec 01, 2024 6:58 pm
MKB20_v77_The_Mandalorian-_Season_3_Disc_1_D61A : 043674A897095B25DE9FE805F24FAB810E57BB07
MKB20_v77_The_Mandalorian-_Season_3_Disc_2_A496 : E68415D9656A82CC0FD6039D47CB81B798C39A79
keydb_helper
Re: DUMP Submitted Mandalorian S3
#2 Post by keydb_helper » Sun Dec 01, 2024 11:29 pm
The D61A and A496 Mandalorian season 3 discs have been added to the public keydb
Public KeyDB Disc Submissions
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
#3 Post by SamuriHL » Mon Dec 02, 2024 12:21 am
Confirmed working. Thanks!
DocShaker
#4 Post by DocShaker » Mon Dec 02, 2024 1:04 am
MKB20_v77_The_Mandalorian-_Season_3_Disc_2_03BE
phantomapollyon
#5 Post by phantomapollyon » Mon Dec 02, 2024 9:21 pm
Disc 1 for me worked using the public DB, but Disc 2 did not. (submitted the dumps of course)
mb3000
#6 Post by mb3000 » Mon Feb 17, 2025 4:22 pm
Dump files submitted.
#7 Post by SamuriHL » Mon Feb 17, 2025 4:27 pm
They're not in the KEYDB. I was unable to find the unit keys. I know they were created on Pioneer drives so I'm not sure if someone can process them or not for the KEYDB.
mb3000
#8 Post by mb3000 » Mon Feb 17, 2025 4:36 pm
These dump files is created on an ASUS drive 8)
#9 Post by SamuriHL » Mon Feb 17, 2025 5:01 pm
Sorry, yes looking at the wrong thing. Yea, hopefully someone will be able to add them.
keydb_helper
#10 Post by keydb_helper » Tue Feb 18, 2025 12:13 am
MKB20_v77_THE_MANDALORIAN_SEASON_3_D1_3796.tgz
MKB20_v77_THE_MANDALORIAN_SEASON_3_D2_48F4.tgz
The 3796 and 48F4 Mandalorian discs have been added to the public keydb
mb3000
#11 Post by mb3000 » Tue Feb 18, 2025 6:23 am
Thank you!
bobbyhugepike
#12 Post by bobbyhugepike » Wed Feb 26, 2025 10:11 pm
Hello everyone,
I've added two dump files, created with a Pioneer BDR-12EBK (BD-RW BDR-S12U flashed for UHD).
The last KEYDB.cfg doesn't work.
bobbyhugepike
#13 Post by bobbyhugepike » Sun Mar 09, 2025 2:52 pm
Thanks a lot for the quick fix. 👍
The updated KEYDB file works now with Pioneer drives.
