DUMP Submitted Mandalorian S3
Post by SamuriHL »
MKB20_v77_The_Mandalorian-_Season_3_Disc_1_D61A : 043674A897095B25DE9FE805F24FAB810E57BB07
MKB20_v77_The_Mandalorian-_Season_3_Disc_2_A496 : E68415D9656A82CC0FD6039D47CB81B798C39A79
keydb_helper
Re: DUMP Submitted Mandalorian S3
Post by keydb_helper »
SamuriHL wrote:
Sun Dec 01, 2024 6:58 pm
The D61A and A496 Mandalorian season 3 discs have been added to the public keydb
Post by SamuriHL »
Confirmed working. Thanks!
DocShaker
Post by DocShaker »
MKB20_v77_The_Mandalorian-_Season_3_Disc_2_03BE
phantomapollyon
Post by phantomapollyon »
Disc 1 for me worked using the public DB, but Disc 2 did not. (submitted the dumps of course)
mb3000
Post by mb3000 »
Dump files submitted.
Post by SamuriHL »
They're not in the KEYDB. I was unable to find the unit keys. I know they were created on Pioneer drives so I'm not sure if someone can process them or not for the KEYDB.
mb3000
Post by mb3000 »
These dump files is created on an ASUS drive 8)
Post by SamuriHL »
Sorry, yes looking at the wrong thing. Yea, hopefully someone will be able to add them.
keydb_helper
mb3000 wrote:
Mon Feb 17, 2025 4:22 pm
MKB20_v77_THE_MANDALORIAN_SEASON_3_D1_3796.tgz
MKB20_v77_THE_MANDALORIAN_SEASON_3_D2_48F4.tgz
mb3000 wrote:
Mon Feb 17, 2025 4:36 pm
The 3796 and 48F4 Mandalorian discs have been added to the public keydb
mb3000
Post by mb3000 »
keydb_helper wrote:
Tue Feb 18, 2025 12:13 am
Thank you!
bobbyhugepike
Post by bobbyhugepike »
Hello everyone,
I've added two dump files, created with a Pioneer BDR-12EBK (BD-RW BDR-S12U flashed for UHD).
The last KEYDB.cfg doesn't work.
bobbyhugepike
Thanks a lot for the quick fix. 👍
The updated KEYDB file works now with Pioneer drives.
