Pioneer BDR-XD05B drive not reading UHD discs
katieb
Post by katieb »
Hi there, I'm a bit of a novice at this stuff so I may be missing something but figured I'd come here for help. I have a Pioneer BDR-XD05B that has worked well for many years and still does with regular blu-ray disc, but I bought a couple UHD discs recently and MakeMKV can not see any UHD discs that I've tried even though regular blu-rays still work perfectly.
I see there's a lot of talk about Pioneer firmwares but I didn't see anything about this drive that was helpful. I also didn't see this drive in the MK firmware pack.
I'm on a fresh install of Windows 11 Pro 22H2 with MakeMKV 1.17.4.
MakeMKV reads the following information from my drive (I left out the serial number):
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Firmware date: 2014-12-26
Highest AACS version: 42
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
I read in another post that the RS8xxx platform should work, and this one does for regular blu-rays just not UHD. Thanks in advance.
johnny_bravo
Re: Pioneer BDR-XD05B drive not reading UHD discs
Post by johnny_bravo »
Hello!
I came looking here because I have the exact same problem with (almost) the exact same drive. I was surprised to find that you'd posted your message only a few hours ago!
I wish I had a solution, but I'm also trying to figure out why this supposedly supported feature isn't working.
I've got the Pioneer BD-RW BDR-XD05, with these specs:
OS device name: /dev/rdisk6
Revision: 3.01
Highest AACS version: 76
I'm using MakeMKV 1.17.4 on macOS Ventura, running on an M1 Mac Mini.
My drive has never been able to do anything with UHD discs besides try to read them about 20 times and then spit out a "no disc inserted" error. The possibility of getting MakeMKV to read them is really exciting, so I'm also very interested in finding out if this is actually possible.
Thanks in advance.
katieb wrote:
Mon Jun 12, 2023 1:44 am
Revision: 3.01
This drive model is not UHD capable.
johnny_bravo wrote:
Mon Jun 12, 2023 4:28 am
Hello!
Revision: 3.01
Thanks in advance.
katieb
Post by katieb »
That sucks, but thanks for the reply!
zittrig
Post by zittrig »
Is this model not UHD capable furthermore? No flash possible?
Friend of mine has a BDR-XD05TS, MFD June 2016 with the same drive information.
zittrig wrote:
Sat Nov 30, 2024 5:40 pm
It should work but these guys posted that almost half a year ago and won't show anymore like many did.
zittrig
Post by zittrig »
Thanks, Coopervid! :)
plafman
Post by plafman »
zittrig wrote:
Sat Nov 30, 2024 7:04 pm
Hi Coopervid,
I see you have PMed a lot of people on here to help them flash their drives. I have a Pioneer BDR-XD05B manufactured in March 2019. Do you mind sharing what I need to do to flash mine to support UHD? I'd PM you, but I just registered so the site won't allow me.
Thank you.
OS device name: E:
Revision: 3.10
Firmware date: 2017-06-22
Highest AACS version: 68
Drive platform: RS8232
Firmware version: 3.10/ID34
low_76
Post by low_76 »
Anyone ever reply to this with any actual definitive information ?
I was going through some drives and found this Pioneer model BDR-XD05B, manufacture date 2018. I too would like to use it for UHD if its possible. There was never a response to this thread with a definitive, "It won't read UHD, ever". So, is it a lost cause ? Or is there some trick now to get it reading UHD ?
email me the drive info from makemkv on a windows pc
see email below
DC-2187
Post by DC-2187 »
billycar11,
I sent over an email with my drive information. wondering if 4k flash would be possible.
thanks for your time.
-daniel
