hi all,
as i write in the title i was wondering if it usually makes any difference whether a you back up your Blu-Ray discs with a drive that is libredrive-enabled or one that is not.
Are backups made with a libredrive-drive in any way more accurate?
thanks in advance
does it make any difference whether Blu-Rays are backed up with libredrive enabled drives or non-libredrive drives?
shisha0505
Re: does it make any difference whether Blu-Rays are backed up with libredrive enabled drives or non-libredrive drives?
I think they should be the same.
LibreDrive is required to be able to rip UHDs. If your non-LibreDrive optical drive works with MakeMKV, it should be fine for most DVDs and regular blu-rays.
