Backup was fine but the rip from said backup has a bunch of debug codes.
Cultural-Climate9187
Post by Cultural-Climate9187 »
Hi, I have ripped Attack on Titan: Season 2 the Funanimation one and I usually create a backup then rip from said backup, i have created two backups so i can test to see if it was a faulty backup though there are no error codes when making the backup just when ripping to MKV which i get this error.
DEBUG: Code 0 at :WQfc~\>#=_|hz]uopm:121261911
DEBUG: Code 3199971767 at NA*r*2BG==&AH:213132537
The files appear to work that is depositied no idea what the issue is though.
Re: Backup was fine but the rip from said backup has a bunch of debug codes.
I use a similar workflow to you and I occasionally get some DEBUG codes in the logs. I've never noticed them to be a problem so I don't worry about them.
MakeMKV is usually pretty clear when there's some kind of real error. DEBUG codes in the log are merely informational for the developer of MakeMKV.
mcleveland92
Post by mcleveland92 »
I am getting the same issue with S01 Attack on Titan. I assume I am going to get the same log for S02 too.
