Error writing file
Error writing file
Trying to MKV ISO file and I get the below debug log after error writing file
MakeMKV v1.6.15 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\woody/MakeMKV_log.txt
Title #0 was added (6 cell(s), 1:34:52)
Saving 1 titles into directory Q:/Torrific/War Zone, The
DEBUG: Code 186 at =d3J[W*F2Ajo`_2Ht45eG0:213129823
DEBUG: Code 600 at aunO=lJAWqIjw[[SDBEZO:213133250
DEBUG: Code 2025 at aunO=lJAWqIjw[[SDBEZO:213133250
DEBUG: Code 111 at aunO=lJAWqIjw[[SDBEZO:213133250
DEBUG: Code 20 at bCs<Y/4t@TU?,NDiE<x:121266626
DEBUG: Code 149 at bCs<Y/4t@TU?,NDiE<x:121266925
DEBUG: Code 3 at bCs<Y/4t@TU?,NDiE<x:29398737
DEBUG: Code 0 at aunO=lJAWqIjw[[SDBEZO:213134377
Failed to save title 0 to file Q:/Torrific/War Zone, The/title00.mkv
0 titles saved, 1 failed
Re: Error writing file
Hi!
Try using your original, commercial DVD as the source, rather than the .ISO image file...
- Contact:
It's a new structure protection and a known bug in MakeMKV - will be fixed in a next version.
Any idea when the new version is to be released?
@woodyns
While waiting for the next update, perhaps you can do as I suggested?:
- Contact:
This is a confirmed bug in 1.6.15, will be fixed in 1.6.16 . It will be available in a couple of days.
Just installed the latest version 1.7 and the error remains the same...
- Contact:
Not want to sound rude, but can you double check? Do you see 1.7.0 in "about" box?woodyns wrote:Just installed the latest version 1.7 and the error remains the same...
Affirmative.mike admin wrote:Not want to sound rude, but can you double check? Do you see 1.7.0 in "about" box?woodyns wrote:Just installed the latest version 1.7 and the error remains the same...
- Contact:
Ouch, that sounds strange. Then please do a testump with 1.7.0 for the title that fails, please see http://www.makemkv.com/onlinehelp/testdump.html . Thank you.
mike admin wrote:Ouch, that sounds strange. Then please do a testump with 1.7.0 for the title that fails, please see http://www.makemkv.com/onlinehelp/testdump.html . Thank you.
Ok file created and I sent you the link to support@makemkv.com. It will take a couple of hours till you can see the file as my upload is a bit slow. thanks
