Why has make MKV stopped working with Mac?
natra
Post by natra »
Hi, I'm wondering why is make MKV not working anymore with Mac?
Re: Why has make MKV stopped working with Mac?
natra wrote: Fri Nov 29, 2024 7:22 am Hi, I'm wondering why is make MKV not working anymore with Mac?
It is working on my Mac. In fact, it is running in the background as I type this.
What is happening on your Mac?
natra
Post by natra »
dcoke22 wrote: Fri Nov 29, 2024 7:24 am
On mine, it hasn't worked for months. I've only used my Windows computer. The problem that I am having is I can hear the disc is skipping about 2 to 3 minutes into the rip and then at the end it almost just stops.
Are you using the same optical drive on both your Mac and your Windows computer or does each computer have a separate optical drive?
And does your Mac have this behavior with 1 particular disc or with all discs that you try?
natra
Post by natra »
dcoke22 wrote: Fri Nov 29, 2024 1:52 pm Are you using the same optical drive on both your Mac and your Windows computer or does each computer have a separate optical drive?
I only have one optical drive and it happens with every movie and I have a Mac mini M1.
natra wrote: Fri Nov 29, 2024 11:39 pm
Probably a power issue.
What's the error show us the log
natra
Post by natra »
Billycar11 wrote: Sat Nov 30, 2024 12:13 am
Thanks, man you were right. It was the power supply. It was not all the way in because I'm using adapter one thing I can recommend to everybody does ripping a lot is to buy a 5V fan and put it on top of the optical drive.
natra
Post by natra »
I thought I fixed the problem but when I watch some movies I saw it some parts of the movies just start to stutter and every time I try to rip on my Mac M1 about 1500 to 1700 M then I can hear the drive skipping I have tried different cables and it's all the same. Then I go to my windows with the same cables and I'm having no issues does anybody else have this problem?
