Alien: Romulus Dump Submitted
Ralph P.
Post by Ralph P. »
Greetings,
MKB20_v77_Alien-_Romulus_44FA
Submitted.
Regards,
AdB391U
Re: Alien: Romulus Dump Submitted
Post by AdB391U »
MakeMKV doesn't seem to be able to open Alien Romulus 4k. I am fairly new to using MakeMKV. What does "Dump Submitted" mean?
"Dump submitted" means that the TGZ file generated by MakeMKV has been sent to svq@makemkv.com for processing.
AdB391U
Post by AdB391U »
Cool, thanks for that.
AdB391U
Post by AdB391U »
How do I know the TGZ file has been processed? Do I have to do anything or does MakeMKV update itself automatically?
deltalizer
Post by deltalizer »
Submitted MKB20_v77_Alien-_Romulus_7590
Generally speaking, when the file has been processed, the update will be automatically picked up by your copy of the program.
There are things that can prevent that, though. If MakeMKV cannot contact its server to pick up the file, you'll see an error message about that, although it's easy to miss.
vascowhite
Post by vascowhite »
I have also submitted
MKB20_v77_Alien-_Romulus_7590.tgz
I think it is different to the one already submitted.
AdB391U
Post by AdB391U »
How long does this process normally take? Am I right to assume that only one person has to submit the TGZ file or should I do it as well?
AdB391U wrote:
Mon Dec 02, 2024 10:25 pm
If your dump file has a different name than what people have already submitted, then you should submit your dump file as well.
If your dump file is the exact same name, then you don't need to submit your dump, but it doesn't hurt.
AdB391U
Post by AdB391U »
The dump file has the same name but I submitted it anyway.
keydb_helper
Post by keydb_helper »
A full record for some UHD variant of Alien: Romulus has been added to the public keydb. I'm not sure which MakeMKV disc dumps it might assist with decrypting. It has the libaacs disc ID 0x2FCACD2FC8D6EFD7A9C75448C30F96F453348043
Public KeyDB Disc Submissions
Ralph P.
Post by Ralph P. »
keydb_helper wrote:
Wed Dec 04, 2024 2:37 am
Greetings,
The Keydb. worked with my copy. Thank you!
Regards,
AdB391U
Post by AdB391U »
It's worked for me as well. Thanks everyone.
Ballesteros
Post by Ballesteros »
The "_7590" disc (UK UHD release) is also decrypting for me today, and I hadn't updated my keydb since it failed a couple of days ago, so the key must have been added through Makemkv.
