Subtitles Burn In Nonsense Tell All
HappyIdiot
#1 Post by HappyIdiot » Thu Nov 28, 2024 12:58 am
For Passion of the Christ or Game of Thrones and any movie that uses minor captions (Black Panther), the subtitles won’t show up unless they’re marked forced
Unless you mark the correct “forced subtitle” with “df” (default/forced) in Expert Mode in MKV, you still need a player that plays forced subtitles automatically
- VLC Player, does NOT play forced subtitles automatically
- MPV Player does play forced subtitles automatically
- Great program for testing
MKVToolNix
- In the header editor section, toggle default and forced on the correct subtitle
- Then, click save via the header editor toolbar
- Loading and saving in MKVToolNix takes time, so be patient
- 64-bit version kept crashing, so use the 32-bit version
Other
- There might be a discrepancy between language and subtitles playing automatically, as some movies’ sound language is marked for something other than english (you’ll see all that in MKVToolNix)
- default/forced, it looks to be better to mark both for the forced subtitles (df)
- Handbrake will compress your videos when recording “burn in” subtitles meaning you’ll lose quality
- The program Mediainfo can offer insight into the correct “forced subtitle” from the MKV
- There’s an additional subtitle editor program that can be looked at for answers as well
Take aways
- Actual movie studios use “burn in” via premiere or some other video editing program
- Realistically, I personally will not be chasing these subtitles except for movies completely in another language
- Secondly, since I use VLC on my XBOX for all my MKV watching, so I’ll simply toggle the correct english forced subtitle for movies like Black Panther or just miss out on them completely (Game of Thrones)
Re: Subtitles Burn In Nonsense Tell All
#2 Post by Woodstock » Thu Nov 28, 2024 2:15 am
Dealing with subtitles for 90+% of stuff I rip, the "forced subtitles" are rarely tagged as such. I've had two movies that did so properly; the closest others have been ones where they encoded the video with the forced subtitles, rather than using a subtitle track (Star Trek movies are typical examples), although those often have an "everything" subtitle track in addition to those.
You're GOING to have to make use of something like mkvtoolnix to tag tracks as "forced", even after running the MKV files through something like handbrake to re-arrange the order of the subtitle tracks. Few tools will tag the tracks correctly for all players. You want the track you want to see "all the time" tagged as both "Default" and "Forced".
If you're converting to something like MP4 files, where they have to be burned in, then flags don't matter.
As for "takes time", if you know what you want mkvtoolnix to do in advance, you can put it on the command line, and have it happen almost instantly. I use a batch file to do it, and it can do an entire TV series in under a minute.
flojo
#3 Post by flojo » Thu Nov 28, 2024 3:47 am
Multiple subtitle streams marked: "default_track": true, are displayed based on FIFO. Ignore "forced_track" and "enabled_track" and pretend "default_track" is the only one.
Don't use mediainfo, use "mkvmerge -J <file>" as recommended by all mkvtools. No matter how the .mkv file is created, a player generally adheres to the specification, so the track ID/order given by mkvmerge -J is ultimately what the player should/will use.
I have a unfinished Python script I made for cartoons/anime, for which it disables Japanese audio and subtitles but only _IF_ English audio is found. It's good if all you want is <language> audio and either no subtitles or only forced <language> subtitles. If interested, I could clean it up and put it on gitlab. It does _NOT_ remux, it uses mkvpropedit.
 one_lang.py:
 Required Options:
  -i, --input_file  file to modify ie. "./video.mkv"
  -a, --audio-language
                        3 letter language to use, eg: "eng" (see:
                        https://en.wikipedia.org/wiki/List_of_ISO_639_language_codes)
  -s, --subtitle-language
Mutually Exclusive Subtitle Options:
  -d, --disable-all-subtitles
                        unsets/disables all subtitles (default: False)
  -o, --enable-one-matching-subtitle
                        match one non-forced subtitle if possible, forced if not possible (default: False)
  -x, --use-subtitle-track-number
                        uses this subtitle track number. Useful if always wanting a certain track (default: -1)
  --default-subtitle-operation
                        the normal operation that happens by default if you don't choose 1 of the subtitle exclusives
Mutually Exclusive Audio Options:
  -y, --use-audio-track-number
                        uses this audio track number. Useful is always wanting a certain track (default: -1)
  --default-audio-operation
                        the normal operation that happens by default if you don't choose 1 of the audio exclusives
Options:
  -p, --audio-codec-priority
                        CSV list of codec names (default: DTS-HD Master Audio,E-AC-3,TrueHD,AC-3 Dolby Surround
                        EX,DTS-ES,A_MS/ACM,DTS,AC-3,FLAC,PCM) (see:
                        https://www.matroska.org/technical/codec_specs.html)
  -n, --no-subtitle-modifications
                        disable all subtitle modifications (default: False)
  -j, --no-audio-modifications
                        disable all audio modifications (default: False)
  -g, --enable-one-matching-subtitle-if-no-matching-audio
                        if no matching audio, enables one matching subtitle (default: False)
  -f, --search-for-force-in-subtitle-track-name
                        additionally search for "force" in track name. Handy if the track does not have the forced
                        property set, but does have the word "Forced" in a subtitle track name matching your chosen
                        language (default: False)
  -w, --filter-regex-from-subtitle-track-names
                        when choosing a subtitle track, this will use re.search() to filter _OUT_ any matches. You can
                        use a regular string eg. -g '(?iu)commentary' (default: "") (see:
                        https://docs.python.org/3/library/re.html)
  -z, --filter-regex-from-audio-track-names
                        when choosing a audio track, this will use re.search() to filter _OUT_ any matches. You can
                        use a regular string eg. -c '(?iu)commentary' (default: "") (see:
  -k, --replace-title-with-filename
                        replaces the global file title with the its own filename minus extension (default: False)
  -t, --remove-title    removes the file's title property (default: False)
  -r, --remove-all-tags
                        strips all tags, note: tags are _NOT_ chapters (default: False)
  -b, --mkvmerge-bin
                        link to mkvmerge, ie. /usr/bin/mkvmerge (default: $PATH)
  -e, --mkvpropedit-bin
                        link to mkvpropedit ie. /usr/bin/mkvpropedit (default: $PATH)
  -m, --print-audio-codecs
                        print a comma separated list of audio codecs then exit (default: False)
  -c, --print-video-codecs
                        print a comma separated list of video codecs then exit (default: False)
  -u, --print-subtitle-codecs
                        print a comma separated list of subtitle codecs then exit (default: False)
  --parse-mode-full     uses the full parse mode of mkvpropedit, which takes much longer, but may be needed for
                        broken/corrupt files (default: False (fast mode))
Usage example:
./one_lang.py -a "eng" -s "eng" -f -w '(?iu)comment' -z '(?iu)comment' -i ./video.mkv
HappyIdiot
#4 Post by HappyIdiot » Sat Oct 04, 2025 10:46 pm
11/27/2024 was my original post and today is 10/4/2025 and boy did I get this all wrong
In Plex, I finally found the magical setting that got subtitles to work. This work does NOT work on every version of Plex (XBOX Series X) Anyways... here are my notes:
-For Amazon Fire TV in Plex go to Settings>Video>Burn Subtitles>Only Advanced Formats[/list]
<>Works with both PGS and SRT (via More>Playback Settings>Select subtitle>(scroll to bottom) More> SRT (Open subtitles)
<<>>Personally I prefer the PGS subtitles to SRT
-Plex for Web go to Plex Web>Player>Burn Subtitles>Only image formats
-XBOX Does NOT have this feature
The issue was, without "Only Advanced Formats" or "Only image formats" checked, it is that the entire video will encode the subtitles within the video. This shot my CPU to 95% usage, while causing stuttering on my Fire TV. The reason why I got into subtitles is a college roommate liked watching TV with subtitles, and I just never stopped.
Otherwise, speaking of Fire TV on Plex, the final (hopefully) tweak I did was to go into settings: Advanced>Allow insecure connections>On same network, and this stopped droppages every couple minutes.
