Sgt Frog season 1 disc 1
crazy4nookie
#1 Post by crazy4nookie » Wed Oct 12, 2011 7:15 am
Should be seven episodes, but only finding one 0:23 long title.
Re: Sgt Frog season 1 disc 1
#2 Post by Woodstock » Sat Oct 15, 2011 3:15 pm
Without reading the attached ZIP file, when the disk is being opened, do you see a lot of "Fake cells occupy XX% of the title - assuming fake title" messages?
I see a lot of Funimation disks that had this "fake title" problem with earlier versions of MakeMKV, less so with versions after 1.6.12. However, I was able to rip both disks of the Sgt. Frog Season 1 Part 1 set using 1.6.8; haven't tried with more recent versions.
crazy4nookie
#3 Post by crazy4nookie » Sat Oct 15, 2011 7:48 pm
Here's what I'm getting, I'm afraid I don't really understand any of it:
Debug log started at Wed Oct 12 07:06:25 2011 , written by MakeMKV v1.6.15 darwin(x86-release)
Using 458880KB for read cache.
001005:0000 MakeMKV v1.6.15 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/doug/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL OPTIARC DVD RW AD-5670S 2AHI" opened in DASPI v1.3 mode.
003025:0000 Title #0 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #2 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #3 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003013:0000 Title #4 with special attributes was skipped
003013:0000 Title #5 with special attributes was skipped
003013:0000 Title #6 with special attributes was skipped
003013:0000 Title #7 with special attributes was skipped
003013:0000 Title #8 with special attributes was skipped
003013:0000 Title #9 with special attributes was skipped
003013:0000 Title #10 with special attributes was skipped
003013:0000 Title #11 with special attributes was skipped
003013:0000 Title #12 with special attributes was skipped
003013:0000 Title #13 with special attributes was skipped
003013:0000 Title #14 with special attributes was skipped
003013:0000 Title #15 with special attributes was skipped
003013:0000 Title #16 with special attributes was skipped
003013:0000 Title #17 with special attributes was skipped
003013:0000 Title #18 with special attributes was skipped
003013:0000 Title #19 with special attributes was skipped
003013:0000 Title #20 with special attributes was skipped
003013:0000 Title #21 with special attributes was skipped
003013:0000 Title #22 with special attributes was skipped
003013:0000 Title #23 with special attributes was skipped
003013:0000 Title #24 with special attributes was skipped
003013:0000 Title #25 with special attributes was skipped
003013:0000 Title #26 with special attributes was skipped
003013:0000 Title #27 with special attributes was skipped
003013:0000 Title #28 with special attributes was skipped
003013:0000 Title #29 with special attributes was skipped
003013:0000 Title #30 with special attributes was skipped
003013:0000 Title #31 with special attributes was skipped
Title skip vts=4 pgcn=1 hash=C5A96F7F489213C1
003028:0000 Title #32/0/8 was added (5 cell(s), 0:23:33)
001003:0020 DEBUG: Code 561199 at v):eexv?`#A{[<[3:121262693
001003:0020 DEBUG: Code 0 at XW]SX?FLeH:7t5{$(z:29403176
001003:0020 DEBUG: Code 0 at XW]SX?FLeH:7t5{$(z:29403866
003015:0000 Title #32/0/9 (2:44:55) was skipped due to navigation error
001003:0020 DEBUG: Code 562655 at XW]SX?FLeH:7t5{$(z:29398438
003015:0000 Title #32/0/17 (2:44:55) was skipped due to navigation error
001003:0020 DEBUG: Code 1118673 at v):eexv?`#A{[<[3:121262693
003015:0000 Title #32/0/18 (2:44:55) was skipped due to navigation error
001003:0020 DEBUG: Code 1120129 at XW]SX?FLeH:7t5{$(z:29398438
003015:0000 Title #32/0/26 (2:44:55) was skipped due to navigation error
001003:0020 DEBUG: Code 1674720 at v):eexv?`#A{[<[3:121262693
003015:0000 Title #32/0/27 (2:44:55) was skipped due to navigation error
001003:0020 DEBUG: Code 1676112 at v):eexv?`#A{[<[3:121262693
003015:0000 Title #32/0/31 (2:44:55) was skipped due to navigation error
001003:0020 DEBUG: Code 1676176 at XW]SX?FLeH:7t5{$(z:29398438
003015:0000 Title #32/0/35 (2:44:55) was skipped due to navigation error
001003:0020 DEBUG: Code 2229006 at v):eexv?`#A{[<[3:121262693
003015:0000 Title #32/0/36 (2:44:55) was skipped due to navigation error
001003:0020 DEBUG: Code 2230398 at v):eexv?`#A{[<[3:121262693
003015:0000 Title #32/0/40 (2:44:55) was skipped due to navigation error
001003:0020 DEBUG: Code 2230462 at XW]SX?FLeH:7t5{$(z:29398438
003015:0000 Title #32/0/44 (2:44:55) was skipped due to navigation error
001003:0020 DEBUG: Code 2786661 at v):eexv?`#A{[<[3:121262693
003015:0000 Title #32/0/45 (2:44:55) was skipped due to navigation error
001003:0020 DEBUG: Code 2788053 at v):eexv?`#A{[<[3:121262693
003015:0000 Title #32/0/49 (2:44:55) was skipped due to navigation error
001003:0020 DEBUG: Code 2788117 at XW]SX?FLeH:7t5{$(z:29398438
003015:0000 Title #32/0/53 (2:44:55) was skipped due to navigation error
001003:0020 DEBUG: Code 3342826 at v):eexv?`#A{[<[3:121262693
003015:0000 Title #32/0/54 (2:44:55) was skipped due to navigation error
001003:0020 DEBUG: Code 3344282 at XW]SX?FLeH:7t5{$(z:29398438
003015:0000 Title #32/0/62 (2:44:55) was skipped due to navigation error
003025:0000 Title #32/0/63 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003010:0000 Can't locate a cell for VTS 4 TTN 2 PGCN 2 PGN 1
003010:0000 Can't locate a cell for VTS 4 TTN 3 PGCN 3 PGN 1
003010:0000 Can't locate a cell for VTS 4 TTN 4 PGCN 4 PGN 1
003010:0000 Can't locate a cell for VTS 4 TTN 5 PGCN 5 PGN 1
003010:0000 Can't locate a cell for VTS 4 TTN 6 PGCN 6 PGN 1
003010:0000 Can't locate a cell for VTS 4 TTN 7 PGCN 7 PGN 1
003010:0000 Can't locate a cell for VTS 4 TTN 8 PGCN 8 PGN 1
003010:0000 Can't locate a cell for VTS 4 TTN 9 PGCN 9 PGN 1
003010:0000 Can't locate a cell for VTS 4 TTN 10 PGCN 10 PGN 1
003013:0000 Title #42 with special attributes was skipped
003013:0000 Title #43 with special attributes was skipped
003013:0000 Title #44 with special attributes was skipped
003013:0000 Title #45 with special attributes was skipped
003013:0000 Title #46 with special attributes was skipped
003013:0000 Title #47 with special attributes was skipped
003013:0000 Title #48 with special attributes was skipped
003013:0000 Title #49 with special attributes was skipped
003013:0000 Title #50 with special attributes was skipped
003013:0000 Title #51 with special attributes was skipped
003013:0000 Title #52 with special attributes was skipped
003013:0000 Title #53 with special attributes was skipped
003013:0000 Title #54 with special attributes was skipped
003013:0000 Title #55 with special attributes was skipped
003013:0000 Title #56 with special attributes was skipped
003013:0000 Title #57 with special attributes was skipped
003013:0000 Title #58 with special attributes was skipped
003013:0000 Title #59 with special attributes was skipped
003013:0000 Title #60 with special attributes was skipped
003013:0000 Title #61 with special attributes was skipped
003013:0000 Title #62 with special attributes was skipped
003013:0000 Title #63 with special attributes was skipped
003013:0000 Title #64 with special attributes was skipped
003013:0000 Title #65 with special attributes was skipped
003013:0000 Title #66 with special attributes was skipped
003013:0000 Title #67 with special attributes was skipped
003013:0000 Title #68 with special attributes was skipped
003013:0000 Title #69 with special attributes was skipped
003013:0000 Title #70 with special attributes was skipped
003013:0000 Title #71 with special attributes was skipped
003013:0000 Title #72 with special attributes was skipped
003013:0000 Title #73 with special attributes was skipped
003013:0000 Title #74 with special attributes was skipped
003013:0000 Title #75 with special attributes was skipped
003013:0000 Title #76 with special attributes was skipped
003013:0000 Title #77 with special attributes was skipped
003013:0000 Title #78 with special attributes was skipped
003013:0000 Title #79 with special attributes was skipped
003013:0000 Title #80 with special attributes was skipped
003013:0000 Title #81 with special attributes was skipped
003013:0000 Title #82 with special attributes was skipped
003013:0000 Title #83 with special attributes was skipped
003013:0000 Title #84 with special attributes was skipped
003013:0000 Title #85 with special attributes was skipped
003013:0000 Title #86 with special attributes was skipped
003013:0000 Title #87 with special attributes was skipped
003013:0000 Title #88 with special attributes was skipped
003013:0000 Title #89 with special attributes was skipped
003013:0000 Title #90 with special attributes was skipped
003013:0000 Title #91 with special attributes was skipped
003013:0000 Title #92 with special attributes was skipped
003013:0000 Title #93 with special attributes was skipped
003013:0000 Title #94 with special attributes was skipped
003013:0000 Title #95 with special attributes was skipped
003013:0000 Title #96 with special attributes was skipped
003013:0000 Title #97 with special attributes was skipped
003013:0000 Title #98 with special attributes was skipped
001003:0020 DEBUG: Code 233 at Pq5wV0hRnOKnt1YQueUnAHb/:0
setarip_old
#4 Post by setarip_old » Sat Oct 15, 2011 8:05 pm
Often indicative of a physically damaged or dirty disc...
#5 Post by mike admin » Sat Oct 15, 2011 9:27 pm
Apparently a variation of copy protection that MakeMKV can't handle. Should be fixed in a next version.
crazy4nookie
#6 Post by crazy4nookie » Sat Oct 15, 2011 10:31 pm
sweet!
:D
