Re: SDFtool Flasher
Commo wrote: Wed Nov 27, 2024 1:17 am I am having an issue. I can not get my drive to flash at all.
Here is from MakeMKV:
OS device name: H:
Product: BD-RE WP50NB40
Revision: 1.03
Serial number: [redacted]
Firmware date: 2121-07-08 16:09
That's because you are doing it wrong. Follow the guide for BP50NB40 SVC NB52 in the first post of this thread.
Scylune
Re: SDFtool Flasher
Post by Scylune »
MartyMcNuts wrote: Tue Aug 18, 2020 1:39 am I have created a windows GUI for the MakeMKV sdftool command line flasher.
Enjoy!! 8)
Hey !
I've just registered here to say THANKS !
Thank you, also thanks to everyone that contributed to this ^^
I've received like half a hour ago my BH16NS55 from amazon warehouse. It was cheap :)
(label on it : manufactured 2024/04 -- well I tried anyway ^^)
SDFTool 1.3.5 + HL-DT-ST-BD-RE_BH16NS55-1.05-NM00400-212004211049.bin + START : YES ! It works ^^
So, thanks again eveyone :mrgreen:
CrashOveride
Re: SDFtool Flasher
Post by CrashOveride »
MartyMcNuts wrote: Sat Nov 23, 2024 1:55 am Which version of MakeMKV are you using? Is it a fresh install? If so, you may need to insert a standard blu-ray disc first and open it in MakeMKV so that the latest SDF can be downloaded.
Also, your drive is not one of the common models so the GUI may not work with it. You may have to use the command line instead.
Apologies, I was able to figure it out before the post had even been approved; I had to reinstall MakeMKV
After the reinstall the GUI worked flawlessly and I was able to flash the HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936 firmware just fine, and it's worked great so far
Gassious
Re: SDFtool Flasher
Post by Gassious »
melkore wrote: Wed Sep 09, 2020 3:06 am When trying to update my drive for the first time I am getting the error in the attached file. I can dump the firmware. I've tried with and without enc enabled.
I'm new to this ripping and am interested in putting all of my discs on a R_volution PlayerPro. Before purchasing the unit I want to be sure I have everything I need to rip my discs.
I have a LG WH16NS60 with 1.03 firmware. When i try to flash the firmware to the HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin, I receive the message "Command produced error code 0Xff056103". Sorry if this has been cover before, I don't have the time and patience to read through all 78 pages of posts. :D
How do I fix this? If i can't be fixed, suggestions on purchasing the best separate external drive would be greatly appreciated.
Mr_Orange
Re: SDFtool Flasher
Post by Mr_Orange »
The original firmware is encrypted so you need to use the "enc" syntax if using the command line. SDFtool flasher should automatically detect it though. If it isn't make sure the "enc" box is ticked.
Re: SDFtool Flasher
Gassious wrote: Sat Nov 30, 2024 7:12 pm
Ensure the drive tray is empty and closed.
Ensure MakeMKV is installed in default location.
zittrig
Re: SDFtool Flasher
Post by zittrig »
Scylune wrote: Fri Nov 29, 2024 4:21 pm
Enjoy!! 8)
Hey !
Enjoy your 4k friendly drive.
If you've issues with ripping speed e.g. try firmware WH16NS60 1.02-MK. This is the recommended one for the compatible internal LG drives.
Gassious
Re: SDFtool Flasher
Post by Gassious »
MartyMcNuts wrote: Sun Dec 01, 2024 1:16 am
Thank you. The drive had a disc in it and removing it worked!
daemon9
Re: SDFtool Flasher
Post by daemon9 »
I just got my BH16NS55 in...
OS device name: E:
Product: BD-RE BH16NS55
Revision: 1.05
Firmware date: 2120-06-18 13:42
Flasher tools don't seem to work at all. Any help would be appreciated.
zittrig
Re: SDFtool Flasher
Post by zittrig »
Which firmware you want flash?
Re: SDFtool Flasher
Post by d00zah »
daemon9 wrote: Tue Dec 17, 2024 1:57 pm I just got my BH16NS55 in...
OS device name: E:
Revision: 1.05
The guide says"
BH16NS55 on any Firmware directly to > WH16NS60 1.02MK
Revision: 1.05 FW is encrypted, so make sure 'Enc' is checked. No disc in tray. Tray closed.
mfrankroro
Re: SDFtool Flasher
Post by mfrankroro »
Hoping someone can tell me how I screwed up. Drive SVC code is NB50. I used Marty's link to DE_LG_BP50NB40-NB50_1.03_MK for the first flash and his BU40N_1.00 for the second one. Tried the drive with latest/registered versions MakeMKV and VLC on Windows 11 and Mac silicon (w/gatekeeper workaround) - both attempted 5 times to read a disc with no luck. This is my first try at this so I won't be surprised if there's a glaringly obvious rookie mistake.
Product: BD-RE BP50NB40
Revision: 1.03
Serial number:
Firmware version: 1.03
Re: SDFtool Flasher
mfrankroro wrote: Wed Dec 18, 2024 9:59 pm Hoping someone can tell me how I screwed up. Drive SVC code is NB50. I used Marty's link to DE_LG_BP50NB40-NB50_1.03_MK for the first flash and his BU40N_1.00 for the second one. Tried the drive with latest/registered versions MakeMKV and VLC on Windows 11 and Mac silicon (w/gatekeeper workaround) - both attempted 5 times to read a disc with no luck. This is my first try at this so I won't be surprised if there's a glaringly obvious rookie mistake.
Revision: 1.03
Serial number:
You have only done the first flash. You must use the recovery option for the second part. Follow the guide in the first post of this thread exactly.
mfrankroro
Re: SDFtool Flasher
MartyMcNuts wrote: Thu Dec 19, 2024 1:56 am
Revision: 1.03
Serial number:
I did exactly like your visual aid. What I haven't mentioned (if it matters) is that out-of-the box, the drive was a BD-RE BP50NB40, NB50 - MT1959, 1.03. Libredrive was "possible - not enabled." I used SDFtool 1.3.5.
I read through this thread and one on Reddit many times and I thought I was well prepared... If this new info doesn't help at all, could it be I had a brain fart and didn't realize that I was supposed to do the "READ" and not just the "WRITE"? I only did the 'WRITE' and then the BU40N "Recovery." I left the Master boot box unchecked for the recovery.
Re: SDFtool Flasher
mfrankroro wrote: Thu Dec 19, 2024 4:23 am
Revision: 1.03
Serial number:
No. Not doing the READ first makes no difference. Also, there's really no need to ever check the boot box.
You still must not have done the recovery part correctly otherwise it would have worked.
1 select recovery
2. In the popup window select the BP50NB40 1.03-MK firmware you currently have on the drive
3 in the firmware drop down box select the BU40N 1.00 firmware
4. Press Start
