I don't know but I think it can do BDXL. I was wondering if it can do it or not. I don't know if it needs to be flashed.
LibreDrive for Pioneer drives
Email me for a flasherWolf359 wrote: Wed Nov 27, 2024 5:32 pm Drive Information
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Serial number: xxxxxxxxx
Firmware date: 2014-12-26
Highest AACS version: 81
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
This one works, right?
tennistmac
And I didn't finish my thoughts. It no longer works with Bluray or 4K. I get an Error Code 3 in the debug logs. Is it tied to everything discussed here that I need to flash or change some settings?tennistmac wrote: Wed Nov 27, 2024 7:25 pm My Pioneer drive worked all through 2023 and into 2024. I think it stopped working in the spring, I'm assuming it is due to upgrades in MakeMKV. I believe I'm good based on the firmware date to continue ripping Blu-ray disks.
Here is my drive info:
Product: BD-RW BDR-XS07U
Revision: 1.01
Serial number: BADL005116UC
Firmware date: 2020-09-03
Bus encryption flags: 13
Drive platform: RS8E21
Firmware version: 1.01/ID05
Nope, nothing to do with flashing.tennistmac wrote: Thu Nov 28, 2024 9:38 pmAnd I didn't finish my thoughts. It no longer works with Bluray or 4K. I get an Error Code 3 in the debug logs. Is it tied to everything discussed here that I need to flash or change some settings?tennistmac wrote: Wed Nov 27, 2024 7:25 pm My Pioneer drive worked all through 2023 and into 2024. I think it stopped working in the spring, I'm assuming it is due to upgrades in MakeMKV. I believe I'm good based on the firmware date to continue ripping Blu-ray disks.
Revision: 1.01
I recently purchased a blu-ray (Wicked Little Letters) my drive wasn't happy reading at all (lots of hunting -> no disc detected). I bought a verbatim 43888 as recommended on this forum and that works absolutely perfectly. Thanks for the good tip. I thought, since I am playing around with this anyways, it might be nice to find out if anything can be done to improve the old drive before I give it away. I searched for my old drive's name in this thread and found a previous user with an earlier FW. Here is my info:
OS device name: E:
Revision: 3.10
Serial number: [redacted]
Firmware date: 2017-06-22
Highest AACS version: 68
Drive platform: RS8232
Firmware version: 3.10/ID34
PM sent.Cyberfly wrote: Sat Nov 30, 2024 1:31 pm Hi,
OS device name: E:
Revision: 3.10
tennistmac
I am at a loss on what has happened then. I have tested this on my previous computer (Windows 11 x86) and new computer (Windows 11 ARM). It can no longer read Blue-Ray or 4K DVDs. It just spits them back out. I have turne don debug logs and I can get DEBUG Code 43620, Code 0, and Code 3. But no error codes.MartyMcNuts wrote: Fri Nov 29, 2024 4:30 amNope, nothing to do with flashing.tennistmac wrote: Thu Nov 28, 2024 9:38 pmAnd I didn't finish my thoughts. It no longer works with Bluray or 4K. I get an Error Code 3 in the debug logs. Is it tied to everything discussed here that I need to flash or change some settings?tennistmac wrote: Wed Nov 27, 2024 7:25 pm My Pioneer drive worked all through 2023 and into 2024. I think it stopped working in the spring, I'm assuming it is due to upgrades in MakeMKV. I believe I'm good based on the firmware date to continue ripping Blu-ray disks.
Revision: 1.01
Any idea or has the disc drive just gone bad?
If no discs work at all (any BD/DVD/CD) on any computer then I'd say both the violet and red lasers have died.tennistmac wrote: Sat Nov 30, 2024 10:25 pmI am at a loss on what has happened then. I have tested this on my previous computer (Windows 11 x86) and new computer (Windows 11 ARM). It can no longer read Blue-Ray or 4K DVDs. It just spits them back out. I have turne don debug logs and I can get DEBUG Code 43620, Code 0, and Code 3. But no error codes.MartyMcNuts wrote: Fri Nov 29, 2024 4:30 amNope, nothing to do with flashing.tennistmac wrote: Thu Nov 28, 2024 9:38 pm
on XS drives when this happens i have seen it be the motor that failed.MartyMcNuts wrote: Sun Dec 01, 2024 1:05 amIf no discs work at all (any BD/DVD/CD) on any computer then I'd say both the violet and red lasers have died.tennistmac wrote: Sat Nov 30, 2024 10:25 pmI am at a loss on what has happened then. I have tested this on my previous computer (Windows 11 x86) and new computer (Windows 11 ARM). It can no longer read Blue-Ray or 4K DVDs. It just spits them back out. I have turne don debug logs and I can get DEBUG Code 43620, Code 0, and Code 3. But no error codes.
only way to tell is to take it apart as the slot load mechanism spins the disc as it goes in and out as it grips it on the edge.
unlike a desktop drive where you can just put it in and eject and see if the disc moved at all.
you can sometimes kick start the motor lol if you want to have an open drive and kick start it every time i did it with one with a dead motor lol
Pioneer BDR-XD08UMB-S w/1.04 FW
Ok. Here you go. From the posts, it sounds like I am screwed until a miracle happens? Been using this model for awhile, but new one not working. Appreciate all the work you guys are doing:Billycar11 wrote: Mon May 27, 2019 5:20 am PSA now most Pioneers come with new fw that prevents them from be crossflashed or downgraded do not buy one for UHD at this time[/u][/b]
Pioneer Drives need Firmware from before December 2022 firmware after this does not work do not update if you have a working one more on this in the coming weeks if they can be flashed. if your pioneer UHD drive does not work post your makemkv drive info here: viewtopic.php?f=19&t=27378
OS device name: /dev/sr0
Product: BD-RW BDR-XD08U
Revision: 1.04
Firmware date: 2024-10-09
Drive platform: Pioneer RS9331
Firmware version: ID05
Re: Pioneer BDR-XD08UMB-S w/1.04 FW
yeah sorry man that wont work i would return it if you can i sill have pioneers with old fw if you want onejohn_galt wrote: Mon Dec 02, 2024 4:04 am
Revision: 1.04
tennistmac
So regular DVDs still work. It was able to read the disc information on multiple discs.Billycar11 wrote: Sun Dec 01, 2024 1:33 amon XS drives when this happens i have seen it be the motor that failed.MartyMcNuts wrote: Sun Dec 01, 2024 1:05 amIf no discs work at all (any BD/DVD/CD) on any computer then I'd say both the violet and red lasers have died.tennistmac wrote: Sat Nov 30, 2024 10:25 pm
Disc Information
Label: RAMONES_DISC_1
Timestamp: 2007-08-14 18:05:27
Protection: CSS/CPPM
Data capacity: 7.41 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
Disc Information
Label: ROGUE_ONE
Timestamp: 2017-01-31 09:16:09
Data capacity: 7.53 Gb
Disc type: DVD-ROM
Disc size: 120mm
But no luck with Blue-Ray or 4K DVDs. I'm guessing it uses the same motor and wouldn't be different based on the type of disc.
CD/DVD use the red laser. Blu-ray uses the violet laser. Sounds like the laser has died.tennistmac wrote: Mon Dec 02, 2024 9:44 pmSo regular DVDs still work. It was able to read the disc information on multiple discs.Billycar11 wrote: Sun Dec 01, 2024 1:33 amon XS drives when this happens i have seen it be the motor that failed.MartyMcNuts wrote: Sun Dec 01, 2024 1:05 am
Disc Information
Disc type: DVD-ROM
Disc size: 120mm
Disc Information
Label: ROGUE_ONE
Disc type: DVD-ROM
Disc size: 120mm
You can try clean the lasers the xs is quite difficult to take apart and put together correctly hard to describe what to do sorrytennistmac wrote: Mon Dec 02, 2024 9:44 pmSo regular DVDs still work. It was able to read the disc information on multiple discs.Billycar11 wrote: Sun Dec 01, 2024 1:33 amon XS drives when this happens i have seen it be the motor that failed.MartyMcNuts wrote: Sun Dec 01, 2024 1:05 am
Disc Information
Disc type: DVD-ROM
Disc size: 120mm
Disc Information
Label: ROGUE_ONE
Disc type: DVD-ROM
Disc size: 120mm
Best I can say is angle the hook clip on the outer shell when you put it back together
@Coopervid, can I get firmware as well?
OS device name: G:
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 77
Drive platform: RS8511
Firmware version: 1.14
