Hi!
I am new here.
And i wonder if there is a way to flash PIONEER BDR-209.
It's an external drive from Asus. I can't get it to work with any 4K UHD movie. It says no disc inserted.
Is it possible to maybe flash it?
Can it still rip from regular Blu-Ray discs after a flash?
Following information below are from MakeMkv software:
OS device name: G:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
Firmware date: 2013-09-10
Highest AACS version: 21
Drive platform: RS8600
Firmware version: E401/ID44
PIONEER BDR-209 UHD 4K support(flash?)
Re: PIONEER BDR-209 UHD 4K support(flash?)
Yeah email me see guide below below
MrNobody
I believe I have the same unit, the Pioneer BDR-209DBK, and I wanted to ask if it can also be modified to burn 4K discs. If so, will it still be able to burn regular BD discs as well?
Thank you
Thank you
Post your Makemkv info and I will send the flasher. Burning will be still supported.MrNobody wrote: Thu Apr 16, 2026 3:42 pm I believe I have the same unit, the Pioneer BDR-209DBK, and I wanted to ask if it can also be modified to burn 4K discs. If so, will it still be able to burn regular BD discs as well?
Thank you
PM sent.HomeKino1337 wrote: Tue Nov 26, 2024 4:37 pm Hi!
I am new here.
OS device name: G:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
Ostermosmergoll
I also have the Pioneer BDR 209, could I also get the flasher?
Thank youOS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-209D
Revision: 1.30
Serienummer:
Firmware-Datum: 2014-12-05
Markierungen der Bus-Verschlüsselung: 13
Highest AACS version: 82
Firmware version: 1.30/ID61
yes email me that drive info see below for emailOstermosmergoll wrote: Fri Apr 17, 2026 1:56 pm Hi,
Produzent: PIONEER
Revision: 1.30
Serienummer:
PM sent.Ostermosmergoll wrote: Fri Apr 17, 2026 1:56 pm Hi,
Produzent: PIONEER
Revision: 1.30
Serienummer:
Timberelf
i just found the same unit in my stash, i would love to get the flasher.
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-209M
Revision: 8.11
Serienummer: QGDL132068WL
Firmware-Datum: 2014-01-16
Firmware version: 8.11/ID52
Thank you.
OS-Gerätename: D:
Produzent: PIONEER
Revision: 8.11
Thank you.
wallegg
Hi everyone,
I am trying to get my Pioneer BDR-209MBK drive to read 4K UHD Blu-rays with MakeMKV.
Currently, standard Blu-rays and DVDs read perfectly, and LibreDrive status shows as Enabled when a standard disc is inserted. However, when I insert a 4K UHD disc, the drive does not recognize it and displays "No disc inserted".
Source: BD-RE ASMedia ASM105x 8.11 OGDL062416WL
Here are my drive details from MakeMKV:
OS device name: K:
Manufacturer: ASMedia
Product: ASM105x
Revision: 8.11
Serial number: OGDL062416WL
Firmware date: 2014-01-16
Highest AACS version: 81
Could someone please point me in the right direction or help me with the correct flasher tool and firmware to enable 4K UHD support for this drive?
Thanks in advance for your help!
wallegg
Hi everyone,
OS device name: K:
Product: ASM105x
Revision: 8.11
wallegg
PM sent.Timberelf wrote: Sat May 02, 2026 7:23 am Hello,
OS-Gerätename: D:
Produzent: PIONEER
Revision: 8.11
Thank you.
PM sent.wallegg wrote: Mon Oct 19, 2026 2:35 pm Hello,
Hi everyone,
OS device name: K:
Product: ASM105x
Revision: 8.11
wallegg
wallegg
Thank You.
Obi_00
Hi everyone,
Currently, standard Blu-rays and DVDs read perfectly, and LibreDrive status shows as Enabled when a standard disc is inserted. However, when I insert a 4K UHD disc, the drive does not recognise it and displays "No disc inserted".
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 8.11
Could someone please point me in the right direction or help me with the correct flasher firmware to enable 4K UHD support for this drive?
Revision: 8.11
Obi_00
Hi everyone,
Revision: 8.11
Revision: 8.11
