PIONEER BDR-209 UHD 4K support(flash?)
HomeKino1337
#1 Post by HomeKino1337 » Tue Nov 26, 2024 4:37 pm
Hi!
I am new here.
And i wonder if there is a way to flash PIONEER BDR-209.
It's an external drive from Asus. I can't get it to work with any 4K UHD movie. It says no disc inserted.
Is it possible to maybe flash it?
Can it still rip from regular Blu-Ray discs after a flash?
Following information below are from MakeMkv software:
OS device name: G:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
Firmware date: 2013-09-10
Highest AACS version: 21
Drive platform: RS8600
Firmware version: E401/ID44
Re: PIONEER BDR-209 UHD 4K support(flash?)
#2 Post by Billycar11 » Tue Nov 26, 2024 6:21 pm
Yeah email me see below
MrNobody
#3 Post by MrNobody » Thu Apr 16, 2026 3:42 pm
I believe I have the same unit, the Pioneer BDR-209DBK, and I wanted to ask if it can also be modified to burn 4K discs. If so, will it still be able to burn regular BD discs as well?
Thank you
#4 Post by Coopervid » Thu Apr 16, 2026 10:12 pm
MrNobody wrote: Thu Apr 16, 2026 3:42 pm I believe I have the same unit, the Pioneer BDR-209DBK, and I wanted to ask if it can also be modified to burn 4K discs. If so, will it still be able to burn regular BD discs as well?
Thank you
Post your Makemkv info and I will send the flasher. Burning will be still supported.
#5 Post by Coopervid » Thu Apr 16, 2026 10:14 pm
HomeKino1337 wrote: Tue Nov 26, 2024 4:37 pm Hi!
I am new here.
OS device name: G:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
PM sent.
Ostermosmergoll
#6 Post by Ostermosmergoll » Fri Apr 17, 2026 1:56 pm
I also have the Pioneer BDR 209, could I also get the flasher?
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-209D
Revision: 1.30
Serienummer:
Firmware-Datum: 2014-12-05
Markierungen der Bus-Verschlüsselung: 13
Highest AACS version: 82
Firmware version: 1.30/ID61
Thank you
#7 Post by Billycar11 » Sat Apr 18, 2026 3:32 am
Ostermosmergoll wrote: Fri Apr 17, 2026 1:56 pm Hi,
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.30
Serienummer:
Thank you
yes email me that drive info see below for email
#8 Post by Coopervid » Sat Apr 18, 2026 9:53 am
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.30
Serienummer:
Thank you
PM sent.
Timberelf
#9 Post by Timberelf » Sat May 02, 2026 7:23 am
i just found the same unit in my stash, i would love to get the flasher.
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-209M
Revision: 8.11
Serienummer: QGDL132068WL
Firmware-Datum: 2014-01-16
Firmware version: 8.11/ID52
Thank you.
