Trying to flash my WH16NS40 - scaling error on sdftools?
Nippi
#1 Post by Nippi » Sun Nov 24, 2024 3:58 am
Hi friends,
This is more a Windows issue than an issue with flashing, so forgive me if this isn't in the right section!
I tried flashing my WH16NS40 drive with the flasher tool and makemkv still says it has original firmware. I noticed I accidentally downloaded the old version of sdftools, so I downloaded the current version, and this is how it looks when I open it on my screen:
I've tried changing the "high dpi scaling" settings, and when I set the program to resize based on the system settings or system settings (enhanced), it will open but nothing appears but a blank window down on the main taskbar.
Nothing I seem to do is working. Does anybody know a way to fix this? I have Windows 11 and am using a 4K television as a monitor. I don't have a separate PC monitor at the moment.
zittrig
Re: Trying to flash my WH16NS40 - scaling error on sdftools?
#2 Post by zittrig » Sun Nov 24, 2024 6:16 pm
Your screen isn't visible. :wink:
#3 Post by MartyMcNuts » Sun Nov 24, 2024 9:24 pm
Nippi wrote: Sun Nov 24, 2024 3:58 am Hi friends,
Did you actually apply the DPI changes in the exe properties?
You could just use the old version if it still causes issues.
Nippi
#4 Post by Nippi » Mon Nov 25, 2024 1:54 am
MartyMcNuts wrote: Sun Nov 24, 2024 9:24 pm
Yes, I apply the changes, then when I try to open it, it just shows a blank window on the task bar and nothing opens.
The problem with the old version is that it didn't flash my drive when I tried to at least twice. It made backups but did not write to the drive. MakeMKV still says I have an original firmware drive when I used the old version.
#5 Post by Billycar11 » Mon Nov 25, 2024 2:24 am
Nippi wrote: Mon Nov 25, 2024 1:54 am
post your makemkv drive info section
you can also use cmd see below in guide
Nippi
#6 Post by Nippi » Mon Nov 25, 2024 4:32 am
Billycar11 wrote: Mon Nov 25, 2024 2:24 am
Oh dear.
It appears under my drive where it says "firmware support", it says no. Does this mean it cannot be flashed? :(
If so... I'll have to return this drive.
Nippi
#7 Post by Nippi » Mon Nov 25, 2024 5:01 am
Here's the drive info section from MakeMKV
#8 Post by Billycar11 » Mon Nov 25, 2024 7:46 pm
Nippi wrote: Mon Nov 25, 2024 5:01 am Here's the drive info section from MakeMKV
It can be flashed use the guide below cmd commands or email me for an auto flasher.
Nippi
#9 Post by Nippi » Tue Nov 26, 2024 6:54 am
Billycar11 wrote: Mon Nov 25, 2024 7:46 pm
Using the command lines worked. Didn't even need the GUI. MakeMKV now shows it is patched. Thank you for your help!
