Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Payti
Re: Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Post by Payti »
I have Pioneer BDR-S09XLT with FW 1.54:
OS device name: P:
Manufacturer: PIONEER
Product: BD-RW BDR-S09
Revision: 1.54
Serial number: MLDL0011xxx
Firmware date: 2020-07-21
Drive platform: RS8600
Firmware version: 1.54/ID43
Could I crossflash my drive to BDR-S11 for 'UHD Friendly'?
Will crosflashed drive Pioneer BDR-S11 compatible with LibreDrive MakeMKV?
Or better crosflash to Pioneer BDR-211M?
Can You help with flasher?
Regards,
Tom
Payti
Post by Payti »
Thanks to @Billycar11.
My Pioneer BDR-S09XLT are now Pioneer BDR-211M FW 1.53 ;-)
Regards,
Tom
lSPk7WduqTfsShca
Post by lSPk7WduqTfsShca »
any chance of the following getting flashed?
It’s a BDE so maybe no?
Drive information
Operating system device name: g:
Product: BDE-PR1EP PP100
Revision: 1.00
Serial number:
Firmware Date: November 30, 2018
Bus encryption identifier: 13
LibreDrive information
Status: Available, but not yet enabled
Driver platform: Pioneer RS8801
Firmware version: ID76
Not inserted
lSPk7WduqTfsShca wrote: Tue Nov 26, 2024 3:24 am any chance of the following getting flashed?
Drive information
Revision: 1.00
Serial number:
Not inserted
believe you emailed me about this looks to be a 211 email me if you want to try it
daemon9
Post by daemon9 »
Looking for some help as well...
OS device name: E:
Revision: 1.20
Serial number: [redacted]
Firmware date: 2014-04-08
Firmware version: 1.20/ID43
daemon9 wrote: Fri Nov 29, 2024 5:18 pm Looking for some help as well...
OS device name: E:
Revision: 1.20
Pm on its way.
deho79
Post by deho79 »
I'm trying to figure out how to flash my S09 so it can read and rip my UHD discs. I wasn't able to find a tutorial online. Is it even possible with my drive?
Revision: 1.54
Serial number: NGXXXXXXXXXX
Highest AACS version: 37
I would really appreciate your help. Thank you!
deho79 wrote: Sun Dec 15, 2024 10:24 pm Hello,
Revision: 1.54
PM sent.
deho79
Post by deho79 »
Coopervid wrote: Tue Dec 17, 2024 11:17 am PM sent.
It worked perfectly. Thank you so much! Happy holidays!
Cristi1992
Post by Cristi1992 »
Hi. I want to flash my drive so it can read 4k bluray, i'm waiting for your help. Thank you.
Drive dated from February of 2023, too late to update.
Cristi1992
The drive it's from 2013 the firmware it's from 2023, i think it can't be flashed because it's released prior octomber 2015. I'm right?
Cristi1992
Woodstock wrote: Mon Dec 23, 2024 3:05 pm Drive dated from February of 2023, too late to update.
I think the drive it's too old, it's released in 2013, the firmware it's from 2023, and if it's prior octomber 2015 released can't be flushed, i'm right?
It's the firmware that includes the lock - If you still had the 2013 firmware installed, you would have those limitations on what the drive can do. But the update to the 2023 firmware locked it to block any further update, backdate, sidedate, whatever.
Cristi1992 wrote: Sat Dec 28, 2024 5:20 pm
Unfortunately you messed it up by installing the 2023 firmware.
