are there any BU40N drives that are really not MT1959 platform?
shisha0505
Post by shisha0505 »
hi all,
i was just wondering if there are any BU40N drives (independently of which manufacturer is labelled on it) which actually are not MT1959 platform.
I'm asking because i have one from HP (which i built into an enclosure) which shows up as "not MT1959 platform" in SDF Tool flasher.
Now according to some discussions it seems not unlikely that wrong enclosures (or rather their backplate sata-usb interfaces) might be the reason why drives falsely are recognized as non MT1959.
So i took the drive out of the enclosure and connected it with a small "mini sata to USB" cable to my PC.
But sdf flash tool still recognizes the drive as non MT1959 so i am wondering if there are BU40Ns that are indeed not MT1959 platform.
Re: are there any BU40N drives that are really not MT1959 platform?
shisha0505 wrote:
Sun Nov 24, 2024 10:42 am
hi all,
Post your Makemkv info. There are indications that LG is not using the Mediatek controller anymore for new drives.
haven't seen bu40n that are not only seen bp50 that are now
use the command line tool to flash if sdf tool is not seeing it right
shisha0505
Coopervid wrote:
Sun Nov 24, 2024 11:39 am
I posted it here not long ago
viewtopic.php?p=162267&sid=2cd9a91cdd88 ... 06#p162267
shisha0505
Billycar11 wrote:
Sun Nov 24, 2024 12:21 pm
no offence but honestly I don't know how to interpret this sentence...🤔
could you kindly point me to a guide how to use the command line tool?
shisha0505 wrote:
Sun Nov 24, 2024 1:22 pm
Back then you received the advice to go for another enclosure or another SATA-USB adapter including a mini SATA - SATA adapter. So you didn't follow this advice it looks like. By just waiting your situation hasn't changed. Either you accept your situation or you try to solve it. This adapter is fairly cheap and supports flashing. And you tried a mini SATA - SATA adapter. Be aware not all SATA ports support flashing as well. Especially chips like Marvell that give you additinal SATA ports. Connect to the ports that are based on the Intel chpset. I have seen issues with AMD chipsets as well. The drive should report the hardware platform when connected.
https://www.amazon.com/-/de/dp/B07JGT17 ... r=8-1&th=1
shisha0505
Coopervid wrote:
Sun Nov 24, 2024 4:22 pm
thanks and
well, actually the advice for a mini-SATA - SATA adapter was my own advice.
Eventually i decided to try another SATA-USB adapter instead of this first idea of my own. As it turned out this didn't work out as hoped and expected.
And that is actually the reason why i started this thread.
Because before i try something else i want to be sure if any BU40Ns exist that are actually physically non MT1959s.
Which i guess obviously would prevent them from getting flashed no matter which adapter i try... :?
shisha0505 wrote:
Sun Nov 24, 2024 4:41 pm
thanks and
Nobody has seen a BU40N that is not based on MT1959. The logical step is to connect it with something that surely supports flashing like the Benfei or with a SATA port that does. You have options.
shisha0505
Coopervid wrote:
Sun Nov 24, 2024 4:51 pm
thanks :-), that was the information i was looking for to be sure if the error is caused by the drive or the adapter.
so i'll stick to my initial idea of connecting the drive directly to a Sata port
Report back, please. We like to know how the story continues.
shisha0505
of course
Literally in my sig is the guide
shisha0505
Update:
...maaaan, this sucks.
I got me a "SATA III to SLIM SATA" cable and connected the drive directly to the mainboard's SATA port.
Now at least it shows up as MT1959 platform in SDFtool Flasher.exe
Then i tried to flash it with "HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin" from the "The all you need firmware pack".
SDFtool Flasher definitely did something but i don't know what because in MakeMKW the drive still shows up as
Product: BDRE BU40N
Revision: BW43
Copying 3D BluRay obviously still works but still no UHD... (where's the "banging head on desk" smiley...?)
Well: nevermind.
Finaly got it to work. I used sdftool_flasher.exe and checked the enc! option. This time flashing was successful, MakeMKV shows the new Firmware and UDH backup seems to work
NCC-1864
Post by NCC-1864 »
Hi there,
it seams I have a similar problem with my HP BU40N (BW43): The SDFtool Flasher says that this drive has not the MT1959 plattform... Therefore I'm not able to update the firmware.
So do I get this right? The issue is not with the drive itself but with the way I connect the drive to my PC? Right now I use this connector:
https://www.amazon.de/gp/product/B07PBG ... UTF8&psc=1
Do you have any suggestions how to connect the drive to a desktop PC so I can actually flash the firmware?
Yethidran
Post by Yethidran »
Try getting this tiny adapter..
if you have a Desktop/Tower Windows PC, open the side cover to gain access into any spare Sata power/connecter..
i use this to directly connect it, for any flashing of slim drives. i personally bought 2 pieces, just incase one doesnt work.
https://www.aliexpress.com/item/1005005 ... 1802SDBuAU
