I am using a Buffalo BRUHD-PU3-BK. The disc often does not load in file explorer and I can hear the disc spinning up and down and up and down. Plays in a normal Blu-ray player fine, all episodes are working in both languages and all extras play.
Manufacturer: BUFFALO
Product: Optical Drive
Revision: 1.03
Serial number: [redacted]
Highest AACS version: 78
Firmware version: 1.03
Disc is the fourth disc of the rising of the shield hero first season.
Disc Information
Label: Rising_Shield_Hero_S1P2_D2
Timestamp: 2020-05-01 09:30:00
Protection: AACS v68
Data capacity: 22.4 Gb
Disc type: BD-ROM
Number of layers: 1
Getting these errors:
Error 'Scsi error - HARDWARE ERROR: TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE BUFFALO Optical Drive 1.03 MO4JBJB4754' at offset '23671734272'
Error 'Scsi error - HARDWARE ERROR: TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE BUFFALO Optical Drive 1.03 MO4JBJB4754' at offset '23671797760'
Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom1' at offset '23671797760'
Error 'Scsi error - HARDWARE ERROR: TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00028.m2ts' at offset '36864'
Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom1' at offset '36864'
Error 'udf: node fe/efe failed!'
Strange issues with a specific disc
Re: Strange issues with a specific disc
Sounds like it's truggling to read the disc or a power issue. Ensure you have connected both cables and also use either ports directly off the motherboard (not case ports) or a powered USB hub with at least 24W.SilvaEevee wrote: Fri Nov 22, 2024 7:25 pm I am using a Buffalo BRUHD-PU3-BK. The disc often does not load in file explorer and I can hear the disc spinning up and down and up and down. Plays in a normal Blu-ray player fine, all episodes are working in both languages and all extras play.
Revision: 1.03
Disc Information
Disc type: BD-ROM
Number of layers: 1
Also, try cleaning the disc with a microfiber cloth. It may help and costs nothing!
SilvaEevee
No improvement from cleaning and trying various ports and hubs sadly. The Buffalo does appear to have a 5v dc barrel jack which can be used instead of a second USB I am guessing? I could get an adapter for a try. I just bought the disc so I could also return it.
SilvaEevee
Fixed! You seem to have been correct with the power issues idea. I tried the USB hub built into my monitor as a long shot and, although the console did spit out some AV sync errors, it did produce the MKV files. They play back perfect. Thanks!
