There are so many instructions that have been convoluted with new versions and versions that say not to do it.
I would appreciate any help with flashing an LG BP60NB10 slim
It's on the model numbers accepted, then it says "do not flash a slim drive"
Egregiously confusing.
TMI here, direct instructions for BP60NB10 slim?
Re: TMI here, direct instructions for BP60NB10 slim?
1st post of the guide is the regularly maintained & current.abuttino wrote: Fri Nov 22, 2024 9:37 pm There are so many instructions that have been convoluted with new versions and versions that say not to do it.
On Windows, use SDFtool FlasherBP60NB10 on any Firmware directly to > BP60NB10 1.02MK
Which of the thousands of words am I supposed to be paying attention to?
There are old versions, then something that says "New!" and it's so hard to understand what is going on.
The flasher is clearly outlined, however, I click on the LG link and they specifically say it's not for a slim drive.
I hope you can understand my complete confusion.
@moderator
Please help clean up that thread into current information and useful so I don't have to post threads like this
Sorry, I thought I had pared it down to a manageable 'bite'...abuttino wrote: Fri Nov 22, 2024 9:54 pm Which of the thousands of words am I supposed to be paying attention to?
From the recommended FW section (in the 1st post) I highlighted the relevant line & provided a link the the FW archive containing the specified FW...
Last folder in the linked archive is... 'LG slim USB BP60NB10'.
The only FW in that folder is 'HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin'.
The SDF Flasher is here .
And this is for the slim drive; correct?d00zah wrote: Fri Nov 22, 2024 10:14 pmSorry, I thought I had pared it down to a manageable 'bite'...abuttino wrote: Fri Nov 22, 2024 9:54 pm Which of the thousands of words am I supposed to be paying attention to?
On the "New!" download the version is:
HL-DT-ST-BD-RE_ WH16NS60-1.02-NMO0100-211810291936.bin
Not 935
it isabuttino wrote: Fri Nov 22, 2024 10:33 pm ...
May I suggest using AI to clean up these posts? It's beyond confusing.
"Do not use this firmware if you have a slim drive"
"Ya! Use that one that says not to use it"
I have emphasized that ONLY the 1st post of these topics is meaningful & regularly maintained. And I've distilled it down to the parts important to you. You insist on reading beyond what you need. Ignore it.abuttino wrote: Fri Nov 22, 2024 11:08 pm May I suggest using AI to clean up these posts? It's beyond confusing
The guide recommends "BP60NB10 on any Firmware directly to > BP60NB10 1.02MK" for your drive.
That FW is provided in an archive listed in that 1st post... reposted here.
The archive contains a number of folders. One of which is named 'LG slim USB BP60NB10'. You asked if this was for the slim drive. 'slim' is contained in the name & when you asked if it was for the 'slim' drive, I responded "it is".
The 'LG slim USB BP60NB10' folder contains the FW you need to flash... 'HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin'. Extract that file & use the SDF Flasher to flash your drive.
AI is junk if you want to tell me how to improve sure I'll add it.abuttino wrote: Fri Nov 22, 2024 11:08 pm May I suggest using AI to clean up these posts? It's beyond confusing.
All the info there is relevant and needed in curtain situations
if thing are to complicated we offer automated services that flash it for you from me and marty
Had you read more carefully, no one has instructed you to do otherwise.abuttino wrote: Fri Nov 22, 2024 9:37 pm ...
Crossflashing Warnings:
1. Don't crossflash desktop drives to slim drives or the other way around
