Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
daiden wrote: Thu Nov 21, 2024 6:24 pm Thank you. I followed the steps, but it seems like the drive can't read any discs that I try (both blu ray and uhd). It'll make loading sounds for a bit and then display "No disc inserted" in makemkv.
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: [removed]
Firmware date: 2020-06-15
Drive platform: RS8A10
Firmware version: 1.14
Anyone experience this and know a fix?
Seems to be a power problem. Use another USB port or both USB cables or a powered USB hub.
Meteo07
Post by Meteo07 »
hi i'm new here and i want to know how read uhd br
i'm under macos and infos are :
PIONEER BD-RW BDR-UD03 :
Révision du programme interne : 1,14
Interconnexion : USB
Gestion de la gravure : Oui (prise en charge de lecteur générique)
Chemin du profil : Aucun
Cache : 4000 Ko
Lecture de DVD : Oui
CD gravables : -R, -RW
DVD gravables : -R, -R DL, -RAM, -RW, +R, +R DL, +RW
BD-Write : -R, -RE
Stratégies d’écriture : CD-TAO, CD-SAO, CD-Raw, DVD-DAO
thanks for your help
regards
Meteo07 wrote: Fri Nov 22, 2024 4:32 pm hi i'm new here and i want to know how read uhd br
Cache : 4000 Ko
BD-Write : -R, -RE
regards
I can help you if you have access to a Windows PC or laptop.
Meteo07
Post by Meteo07 »
it's possible yes
Alex590263
Post by Alex590263 »
Can i have your help to make my blu ray drive able to read UHD blu ray ?
OS device name: H:
Product: BD-RW BDR-UD03
Revision: 1.10
Serial number:
Firmware date: 2017-04-18
Drive platform: RS8511
Firmware version: 1.10
Thank you
paperfeet
Post by paperfeet »
Laufwerksinformation
OS-Gerätename: G:
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer:
Firmware-Datum: 2020-06-15
Highest AACS version: 49
Hi @Coopervid
Can you help me as well with my drive?
Meteo07 wrote: Fri Nov 22, 2024 5:21 pm it's possible yes
You have a PM.
Alex590263 wrote: Fri Nov 22, 2024 5:43 pm Hello,
OS device name: H:
Revision: 1.10
Serial number:
Thank you
PM sent.
paperfeet wrote: Fri Nov 22, 2024 7:06 pm
OS-Gerätename: G:
Produzent: PIONEER
Revision: 1.14
Serienummer:
Hi @Coopervid
PM sent.
Meteo07
Post by Meteo07 »
Coopervid wrote: Fri Nov 22, 2024 8:59 pm
You have a PM.
received, thanks
Alex590263
Coopervid wrote: Fri Nov 22, 2024 9:02 pm
OS device name: H:
Revision: 1.10
Serial number:
Thank you
PM sent.
Thank you!! It works!!!
Meteo07
Post by Meteo07 »
it's working well, thanks
deibit
Post by deibit »
Hi!
I have just got one of these Verbatims with Pioneer UD03 inside, could I please get the PM with the instructions?
Revision: 1.14
Serial number:
deibit wrote: Tue Nov 26, 2024 5:29 pm Hi!
Revision: 1.14
Serial number:
PM sent.
deibit
Post by deibit »
it works! amazing! thank you so much!
