Update to new version
Ijaja
Post by Ijaja »
i have already purchased makemkv.
Now i want to update to new version 1.6.15! How do i do this.
I just tried installation of new version. It did not work, still opening version 1.6.14, although installation states successfull installation ?!!
I tried few times, no changes.
Greets, Ijaja
crowfax
Re: Update to new version
Post by crowfax »
Fully uninstall MakeMKV then install 1.6.15.
Make sure there are NO instances of MakeMKV still running on the machine. There are some circumstances where the command line portion will not stop when it is supposed to - open the task manager, and make sure. As long as it is running, the CLI can't be updated, so you keep running the old version.
Once all copies are stopped (rebooting the machine can accomplish this, too, but that's so tacky!), the install should successfully put the latest version in.
