Need Help
emperormephiles4
Need Help
Post by emperormephiles4 » Thu Nov 21, 2024 11:19 pm
Can anyone tell me what i'm doing wrong? i've flashed the drive and everything seems to be right, but all that happens when i insert an uhd disc is it attempts to read for a few minutes and then says "no disc inserted".
Screenshot 2024-11-21 181338.png (54.01 KiB) Viewed 2567 times
Re: Need Help
Post by Woodstock » Thu Nov 21, 2024 11:28 pm
Just the one disk, or all disks? You don't say, and some disks can have issues.
Re: Need Help
Post by MartyMcNuts » Thu Nov 21, 2024 11:59 pm
emperormephiles4 wrote: Thu Nov 21, 2024 11:19 pm Can anyone tell me what i'm doing wrong? i've flashed the drive and everything seems to be right, but all that happens when i insert an uhd disc is it attempts to read for a few minutes and then says "no disc inserted".
You haven't flashed it correctly. You have only done half the job. The first flash get's you to BP50NB40 1.03-MK. This is not UHD compatible. You must now do the cross-flash to enable UHD ripping. BU40N 1.00 is recommended.
Follow the guide (section about flashing BP50NB40 SVC NB52) in the SDFtool Flasher thread.
emperormephiles4
Re: Need Help
Post by emperormephiles4 » Fri Nov 22, 2024 1:57 am
MartyMcNuts wrote: Thu Nov 21, 2024 11:59 pm
Thank you so much! it was driving me mad trying to figure it out! :D
