LG BU40N
evilmatcher
LG BU40N
#1 Post by evilmatcher » Thu Nov 21, 2024 5:09 pm
Hi
I have used a LG BU40N drive with a Vantec enclosure for 4,5 years without any problems and used the drive less than two weeks ago.
Yesterday i wanted to backup some new films and now Windows and MakeMkv 1.17.6 cannot recognize the drive. There hasn't been any signs until yesterday that the drive should be broke.
The drive spins the disc for 10 seconds when connected to a PC, but nothing happens after that.
I have tried to change cable and tried connecting to two other PCs without luck.
Is the drive just broke or is there anything i could try?
Re: LG BU40N
#2 Post by Billycar11 » Thu Nov 21, 2024 11:02 pm
It possible just the case died you can try replacing it.
But before doing that does the drive still get assigned a driver letter and show up in device manager.
You can also try cleaning the laser it very easy on that drive just eject the tray and both lasers are there I recommend cleaning it with a lint free cloth and some alcohol don't let it air dry have another dry lint free cloth to dry it.
Re: LG BU40N
#3 Post by MartyMcNuts » Fri Nov 22, 2024 12:03 am
evilmatcher wrote: Thu Nov 21, 2024 5:09 pm Hi
If the drive is still showing in Windows, you could try downgrading MakeMKV to a previous version.
Kev7274
Re: LG BU40N
#4 Post by Kev7274 » Sat Nov 23, 2024 5:20 am
What vantec enclosure? I was thinking baout putting a BU40N in a https://www.amazon.com/dp/B0756MZTPG/?c ... dp_it&th=1 and in a Vantec NexStar DX2.
Re: LG BU40N
#5 Post by dcoke22 » Sat Nov 23, 2024 7:38 pm
Kev7274 wrote: Sat Nov 23, 2024 5:20 am What vantec enclosure? I was thinkign baout putting a BU40N in a https://www.amazon.com/dp/B0756MZTPG/?c ... dp_it&th=1 and in a Vantec NexStar DX2.
Vantec used to sell a slim optical drive case, but they stopped selling it a couple of years ago.
https://vantecusa.com/CKEdit/images/files/nst-510s3-bk_flyer.pdf
Re: LG BU40N
#6 Post by Billycar11 » Sat Nov 23, 2024 11:12 pm
That will work sold a few like that because the slim cases went downhill at the end that's why they stopped making them I think
Kev7274
Re: LG BU40N
#7 Post by Kev7274 » Sat Nov 23, 2024 11:50 pm
Billycar11 wrote: Sat Nov 23, 2024 11:12 pm
Great. I'll grab them.
evilmatcher
Re: LG BU40N
#8 Post by evilmatcher » Sun Nov 24, 2024 7:21 am
Billycar11 wrote: Thu Nov 21, 2024 11:02 pm It possible just the case died you can try replacing it.
Windows has not assigned a drive letter and it does not show up in device manager.
I will try to clean up the laser and see if that helps.
Otherwise I probably need to find a new drive as I understand from the posts above that the vantec enclosure is discontinued.
Re: LG BU40N
#9 Post by Billycar11 » Sun Nov 24, 2024 12:20 pm
evilmatcher wrote: Sun Nov 24, 2024 7:21 am
nah if windows does not give it a drive letter the case or drive has died no point cleaning the laser
evilmatcher
Re: LG BU40N
#10 Post by evilmatcher » Tue Nov 26, 2024 5:47 pm
I can see the drive in windows device manager under the dvd/cd-rom drive section.
In properties for the drive windows states: STATUS_DEVICE_POWER_FAILURE.
I will try a new case first.
Any case recommendations?
I took the Vantec back in the days, because it allowed to flash the drive.
I guess that feature is no longer needed as the drive has been flashed. Is that correct, and then can i pick any case that fits the drive?
Re: LG BU40N
#11 Post by Billycar11 » Tue Nov 26, 2024 6:07 pm
evilmatcher wrote: Tue Nov 26, 2024 5:47 pm I can see the drive in windows device manager under the dvd/cd-rom drive section.
Actual slim sata cases are getting hard to find you still want one that can flash just in case and to know it can pass through libredrive commands
Lately I have just been recommending full size vantec 5.25 with 9.5mm bay adapters and some slim sata connecter adapters to full size sata
Kev7274
Re: LG BU40N
#12 Post by Kev7274 » Tue Nov 26, 2024 6:59 pm
Little off topic, is the HLDS BU40N the same?
Re: LG BU40N
#13 Post by Billycar11 » Tue Nov 26, 2024 9:23 pm
Kev7274 wrote: Tue Nov 26, 2024 6:59 pm Little off topic, is the HLDS BU40N the same?
yeah
Kev7274
Re: LG BU40N
#14 Post by Kev7274 » Tue Nov 26, 2024 9:26 pm
Thanks. So I can just flash it with the same LG firmware? Just want to make sure.
Re: LG BU40N
#15 Post by Billycar11 » Tue Nov 26, 2024 9:35 pm
Kev7274 wrote: Tue Nov 26, 2024 9:26 pm Thanks. So I can just flash it with the same LG firmware? Just want to make sure.
yeah see guide below or email me for an auto flasher that does it all for you
