AACS bus encryption
tft10
Re: AACS bus encryption
Post by tft10 »
Thank you for the update Mike. Unfortunately, it still does not work for me in v1.6.13. I am still getting the error messages:
ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE'
I have a new internal Asus drive:
Manufacturer: ASUS
Product: BC-12B1ST
Revision: 1.00
Thank you.
Edit: After uninstalling and re-installing MakeMKV, it seemed to make everything work again. Yay!
jonahlee
Post by jonahlee »
I am having the same problem with 1.6.15
Just got a new LG Drive
Product: BD-RE WH12LS38
Revision: 1.00
Serial number: K98B6LM4033
Firmware date: 2011-06-07 12:34:56
Bus encryption flags: 1F
setarip_old
Post by setarip_old »
@jonahlee
Hi!
Did you try what "tft10" did?
jonahlee
Post by jonahlee »
Thanks, that actually seems to have worked! Nice!
setarip_old
You're quite welcome ;>}
dkmann1987
Post by dkmann1987 »
I am having the same issue as above. I was using 1.6.10 to rip things. Since updating to the new version, I haven't even been able to rip the discs that I already did. I have tried uninstalling and removing all (that I could find) registry entries.
Manufacturer: ASUS
Product: BC-06B1ST
Revision: 1.00
Post by mike admin »
dkmann1987 wrote:I am having the same issue as above. I was using 1.6.10 to rip things. Since updating to the new version, I haven't even been able to rip the discs that I already did.
Please start a new topic and post error log there.
dkmann1987
Solved, thanks though.
BlueManGroup
Post by BlueManGroup »
mike admin wrote:Update: bus encryption is fully supported in MakeMKV 1.6.13 and beyond. You should not get any bus-encryption errors or messages.
Please be advised that some very recently manufactured BD-drives implement a new AACS "feature" - bus encryption. It's a new form of protection currenly present in a very few BD-drive models that adds additional layer of encryption in drive firmware, similarly like DVD drives switched to RPC-2 firmware. Contrary to what you may read elsewhere, no BD-decrypting software supports these drives yet. If you're a "lucky" owner of such drive, your only option is to wait for MakeMKV update; or to use it with official BD players. You can't even use such drive to make an encrypted disc backup as drive will encrypt M2TS files with a drive-specific key. The problem is only with the drive, and has nothing to with a disc - you should be able to open any BD disc with an older drive.
Known BD drives with bus encryption:
HL-DT-ST DVDRWBD CH20N A201G
HL-DT-ST BD-RE UH12LS28 1.003
HL-DT-ST BD-RE BE06LU10 YE03
The current MakeMKV version, 1.6.8 would fail with following error message:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720.. ...
The next version of MakeMKV will have more informative error message. And obviously MakeMKV will be updated to work with such drives once they become mainstream.
I have a Sony BDX-S500U and I've been ripping BDs with no issue, until recently. Suddenly, I've been experiencing this issue, which is what sent me to this thread. Now, all of a sudden, every disc I try to rip, I get this:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0CDBE5C224FAF3D716BB51F7DF5A1E5F1EE to device 'DASPI:IODASPIService:78b56dafefa67d49:'
DEBUG: Code 0 at [3A_y5<ArF\G0>z=1:213130743
DEBUG: Code 0 at t|b1YhhpE($sO%+Y3b:29395034
DEBUG: Code 0 at t|b1YhhpE($sO%+Y3b:121262394
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0BEA05C0683D3C27BB8215E821B106E5451 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
DEBUG: Code 1 at t|b1YhhpE($sO%+Y3b:121262394
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..098CAAFB009527ABB46B613CA12E375A569 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
DEBUG: Code 2 at t|b1YhhpE($sO%+Y3b:121262394
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0897D29ADD65A24260DE4D0F8E532608C4E to device 'DASPI:IODASPIService:78b56dafefa67d49:'
DEBUG: Code 3 at t|b1YhhpE($sO%+Y3b:121262394
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..024D9FE7E02F23556E41390B17B64D0308A to device 'DASPI:IODASPIService:78b56dafefa67d49:'
DEBUG: Code 4 at t|b1YhhpE($sO%+Y3b:121262394
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03EE1B1F39A3F9FE5153173F5CB0BD30769 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B3147AE6F5275A8ED805627E10AABC4B5B to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E186AC2C484A6886F1C64CC6848B3B22EB to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03A2584143D78213EAF44A789DF28F8C141 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..05B7B3314620AA7FB696A3FCAFBB5F94FA7 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0D2B8B30AD4253C33AA574919BC13650E61 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0F09B38BE899AC7222CA79CE650A6860F to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..045D7C3EB8135BD3A8E37E0081FF2B5D997 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0802633DCD1B024A45607A035F19473B6AA to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03F15D7057281DE7BF60E17FC42F85B9FE2 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..02A13E8956EE7D9B54E9D9447747A231BB6 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
DEBUG: Code 0 at t|b1YhhpE($sO%+Y3b:121264234
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0AC90AAEDD19A3A0B1A7AFE9A89AC54A8EF to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0A57F853D9401D5BA15EA173EBB149D1FCE to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0AF61359C97E6FCC57E19AA30087777560F to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0A8931C0E612B26909405FA13C4B8AA90BA to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..082709235F5378039CF9A4A640250B0E24D to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..020D5E6F1CAD5F40C877CD2864EAA358ADF to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0DD99A7D6478AE8AA01FB67660D22BCDE42 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03D296491D65969FB7D1E22405C89C11253 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C0DDE8DD857209226B1B2DFBA135A041F7 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..09AA276A09C8A88947DA6E8EFAECCF56153 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0939E637FC8BFD2FB11A8CDE968A34114A9 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0918142D5610F8200D1B15770C7D4172AE5 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00EF300256328481F7ECE7C7CB893D52DF6 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0D40D9D020B3FA91F0C02321A9E9D8D759D to device 'DASPI:IODASPIService:78b56dafefa67d49:'
DEBUG: Code 0 at %1d-w7ehgQ{ v+;*:121263544
DEBUG: Code 0 at %1d-w7ehgQ{ v+;*:29396897
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00BF5E011B41F15C27B24ABC4D3C6DEBE10 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..07A33BA5F85B47668B9028F30E7B7E1BA91 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0D516D22E144F3136B8257CC0A7D93D48B2 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..011D98CFEA1A38F133491BD3F8F23F94161 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..07CDB0F2A95A3AE89AB4391AB8F2FFEB3F2 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..08D2B78BEB32B4B0B536936A3750339E9B2 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00B80C9CAD7C5D7EED057020CB2B431F5A1 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0BAB384E384298E082A406D529AED5AF5E0 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0F0480FE545FA84FC8F9500D0631B51A30B to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0666B97A72060CA343738127DB504D9AFB5 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0EDEC9B49CE59FE764442F3A7B80349397A to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0EA396A4B0EF7CBFA67AEFD4E196091C268 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0222587D6D4F9B30F52FE6A74EAC0DB4BBA to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E21DDF55D7AC51F8FD8912AC69FB79EEFF to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00207BA6F697658B8DD25F19A35B937B7F8 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..04AE86BFE4FE853A77BA2321D3F8727171A to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0876AF06AE5E336D3B32B03B45479BCB5B5 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0CB770097799583C8691FAC8BBEC8A4D458 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0709FE1E1E0A80EF810AAB1471B70E42CB3 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0FCA99C7F30D352CC2924626EFB5C83FDDA to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0438EAAAC00C3C79C3119C3B98E81C8A5CF to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C2BA3B5010F570905CAF04A22ED9F1AE5D to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0F761979988746F9166F23F2E7C410EAA71 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..046337F2877A554538598046EA9CA55E0ED to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0083187AB7A84B4D06BD28DE3D7DCF9449A to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..037E6652415D2C360ECAC5B10289B1CBAB1 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0ACCF7A53981067FF83678B1A65498F8EBE to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..01A95AD5248C38CF47BE5F0B99EA6A1F1E3 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..062027AF1CD4A4CCBF943CDA5A3110A30A9 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0BD3B887436462095F83EDAE0942E3477D1 to device 'DASPI:IODASPIService:78b56dafefa67d49:'
It seems they all have AACS 3.3, however, so I can't be sure if that may be the culprit or if it's something else. I'm running MakeMKV 1.7.9 on OS X 10.8.2.
BlueManGroup
Wait, scratch that. For some reason I thought I was running 1.7.9, but when I checked again, I was actually only running 1.7.7. :oops: I applied the update and now the discs are all ripping again. :)
ratcvr
Post by ratcvr »
I got following error with TEAC BD-W26SS-BM3 , when tried open a disc supports bus encryption.
MakeMKV v1.12.0 win(x64-release) started
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE TEAC BD-W26SS-B 1.01' at offset '23272093696'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/AACS/MKB_RO.inf' at offset '0'
Manufacturer: TEAC
Product: BD-W26SS-B
Revision: 1.01
Serial number: 0000027705
Bus encryption flags: 13
Disc Information
Label: Star_Trek_Beyond
Timestamp: 2016-09-27 14:35:12
Data capacity: 42.61 Gb
Disc type: BD-ROM
Number of layers: 2
Bus encryption flags: 80
You realize you're replying to a topic that has been dead for 6 years, right?
Bus encryption is not an issue for MakeMKV.
