You have a PM.pipo233 wrote: Sun Nov 17, 2024 4:40 pm i have a pioneer S09 with this info:
Is it possible to flash it to read UHD?
if so how can i get a flasher?
Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Re: Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Thanks coopervid, it works perfectly, it now reads UHD
I have jet another drive, pioneer bdr-209M
Can this one be flashed to read UHD?
See below email me I have a flasher for itpipo233 wrote: Sun Nov 17, 2024 4:40 pm i have a pioneer S09 with this info:
lSPk7WduqTfsShca
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-S12
Revision: 1.01
Serial number: [REMOVED]
Firmware date: 2020-07-21
Highest AACS version: 76
Drive platform: RS8F00
Firmware version: 1.01/ID45
Is this drive possible for UHD?
You have a second PM.lSPk7WduqTfsShca wrote: Tue Nov 19, 2024 9:38 amDrive Information
OS device name: E:
Revision: 1.01
Hello, longtime lurker, first time poster
I also saved one of these drives from a machine which was being WEEEd - MFD is June 2015 so I presume it'll still be on the original FW (S/N begins 0FDL017). I presume this will also need a firmware patch?
Also if there are tools for dumping FW for these models of drives, would anyone have any use for this drive's original FW? If so, happy to donate.
You need to post your Makemkv info to get help.chrisw wrote: Wed Nov 20, 2024 6:59 pm Hello, longtime lurker, first time posterI also saved one of these drives from a machine which was being WEEEd - MFD is June 2015 so I presume it'll still be on the original FW (S/N begins 0FDL017). I presume this will also need a firmware patch?
Sorry, was trying to avoid spamming the thread - see below (with a random BD inserted for testing). Playback is fine in MPC-HC/VLC using Passkey, I've not been able to test rip in MakeMKV yet as it's showing an error about the evaluation period having expired.Coopervid wrote: Wed Nov 20, 2024 7:42 pmYou need to post your Makemkv info to get help.chrisw wrote: Wed Nov 20, 2024 6:59 pm Hello, longtime lurker, first time posterI also saved one of these drives from a machine which was being WEEEd - MFD is June 2015 so I presume it'll still be on the original FW (S/N begins 0FDL017). I presume this will also need a firmware patch?
I've also recently unearthed a BDR-XD07TUHD (toploader USB3 drive) which purports to be UHD compatible but I've not had the means to test that yet.Drive Information
Product: BD-RW BDR-S09
Revision: 1.30
Serial number: OFDL01****WL
Firmware date: 2014-12-05
Highest AACS version: 23
Drive platform: RS8600
Firmware version: 1.30/ID43
Disc Information
Label: MICMACS
Timestamp: 2010-05-11 16:10:18
Protection: AACS v17
Data capacity: 19.91 Gb
Disc type: BD-ROM
Number of layers: 1
lSPk7WduqTfsShca
1.
Drive information
Operating system device name: g:
Product: BD-RW BDR-209D
Revision: 1.51
Serial number:
Firmware Date: May 8, 2018
Bus encryption identifier: 13
LibreDrive information
Drive platform: RS8601
Firmware type: original (no patch applied)
Firmware version: 1.51/ID61
DVD full area: yes
BD raw data reading: Yes
BD original metadata reading: Yes
Unlimited reading speed: Yes
2.
Drive information
Revision: 1.52
Serial number:
Firmware Date: January 11, 2019
Bus encryption identifier: 1B
Firmware version: 1.52/ID43
DVD full area: yes
3.
Drive information
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number:
Firmware Date: December 21, 2017
Firmware version: E114/ID71
DVD full area: yes
4.
Drive information
Product: BD-RW BDR-208D
Revision: 1.10
Serial number:
Firmware Date: August 22, 2012
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: 1.10/ID61
DVD full area: yes
5.
Drive information
Product: BD-RW BDR-S08
Revision: 1.10
Serial number:
Firmware Date: August 28, 2012
Firmware version: 1.10/ID43
DVD full area: yes
So basically some 209s and some 208s
Drive information
Revision: 1.51
Serial number:
DVD full area: yes
2.
Drive information
Revision: 1.52
Serial number:
DVD full area: yes
3.
Drive information
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number:
DVD full area: yes
4.
Drive information
Revision: 1.10
Serial number:
DVD full area: yes
5.
Drive information
Revision: 1.10
Serial number:
DVD full area: yes
PM sent. For the XD07 you also need to post your Makemkv info.chrisw wrote: Wed Nov 20, 2024 11:22 pmSorry, was trying to avoid spamming the thread - see below (with a random BD inserted for testing). Playback is fine in MPC-HC/VLC using Passkey, I've not been able to test rip in MakeMKV yet as it's showing an error about the evaluation period having expired.Coopervid wrote: Wed Nov 20, 2024 7:42 pmYou need to post your Makemkv info to get help.chrisw wrote: Wed Nov 20, 2024 6:59 pm Hello, longtime lurker, first time posterI also saved one of these drives from a machine which was being WEEEd - MFD is June 2015 so I presume it'll still be on the original FW (S/N begins 0FDL017). I presume this will also need a firmware patch?
Revision: 1.30
Disc Information
Label: MICMACS
Disc type: BD-ROM
Number of layers: 1
You have 2 PMs.lSPk7WduqTfsShca wrote: Thu Nov 21, 2024 7:10 am 1.
Drive information
Revision: 1.51
Serial number:
DVD full area: yes
2.
Drive information
Revision: 1.52
Serial number:
DVD full area: yes
3.
Drive information
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number:
DVD full area: yes
4.
Drive information
Revision: 1.10
Serial number:
DVD full area: yes
5.
Drive information
Revision: 1.10
Serial number:
DVD full area: yes
Appreciate it! Checked out the PM, process worked flawlessly and the UHD discs seem to be readable now. Amazing how effortless it was.Coopervid wrote: Thu Nov 21, 2024 11:49 amPM sent. For the XD07 you also need to post your Makemkv info.chrisw wrote: Wed Nov 20, 2024 11:22 pmSorry, was trying to avoid spamming the thread - see below (with a random BD inserted for testing). Playback is fine in MPC-HC/VLC using Passkey, I've not been able to test rip in MakeMKV yet as it's showing an error about the evaluation period having expired.
Revision: 1.30
Disc Information
Label: MICMACS
Disc type: BD-ROM
Number of layers: 1
An interesting side-effect appears to be that something's happened to DVDFab Passkey, which I would sometimes use for playing back BDs on the machine through MPC-HC (bitstreaming the audio and HDR signal via MadVR). It previously worked fine, but now it seems to consistently crash while trying to initialise. Is this just a side-effect of the process or would you expect Passkey to still work?
lSPk7WduqTfsShca
The following two would be 211 v2, I suppose?
6.
OS device name: E:
Revision: 1.31
Serial number:
Firmware date: 2015-05-25
Firmware version: 1.31/ID43
OS device name: E:
Revision: 1.51
Serial number:
Firmware date: 2018-05-08
Firmware version: 1.51/ID43
OS device name: E:
Revision: 1.31
Serial number:
OS device name: E:
Revision: 1.51
Serial number:
my flasher figures all that out for you automatically fyilSPk7WduqTfsShca wrote: Fri Nov 22, 2024 2:11 am The following two would be 211 v2, I suppose?
6.
OS device name: E:
Revision: 1.31
Serial number:
OS device name: E:
Revision: 1.51
Serial number:
