Twilight of the Warriors Walled In Dump File
chrispgriffin
Post by chrispgriffin » Sat Nov 16, 2024 9:34 pm
Dump file submitted: MKB20_v77_Twilight_of_the_warriors_walled_in_C05E
Toad King
Re: Twilight of the Warriors Walled In Dump File
Post by Toad King » Tue Nov 19, 2024 3:27 am
The latest KEYDB has an entry for this disc:
0x0E2BF198E8008FD5CA109C3D7ADADEEB725F4998 = Twilight of the warriors walled | D | 2024-09-26
However, even with this KEYDB copied for MakeMKV the disc still doesn't decrypt. The key is valid and I can play an encrypted backup in VLC with it so I think this is a bug in MakeMKV.
chrispgriffin
Post by chrispgriffin » Tue Nov 19, 2024 5:11 am
Yea, I'm having similar issues with Beetlejuice Beetlejuice and while hunting a fix saw your posts on the doom9 forum as well. Was not able to use FindVUK successfully and fix the problem for either discs, so I'm just hoping it will sort itself eventually at this point
Toad King
Post by Toad King » Tue Nov 19, 2024 5:28 am
According to this thread, MakeMKV will only use VUKs from the KEYDB file, not decrypted UKs. I was able to work around it with other tools but it looks like unless you are okay with fiddling with those you'll have to wait until MakeMKV adds support for the disc or someone uploads the VUK to the KEYDB.
polskasubie
Post by polskasubie » Tue Nov 19, 2024 6:21 pm
i was able to open with the newest keydb (LastUpdate: 2024-11-19 17:52:27)
