Hi, I'm a new member here.
Currently, if a subtitle track contains no forced subtitles, MakeMKV offers a mechanism that eliminates the streams from the finished MKV file. Is it possible to do the same for music with completely forced subtitles?
I have two identical subtitle tracks on my rips, which isn't really a problem but is a little bothersome. The English sign-language subtitle tracks on the Planet of the Apes Trilogy collection are like this.
Is it possible to automatically eliminate redundant forced subtitle tracks?
aqqor
dyoung
Re: Is it possible to automatically eliminate redundant forced subtitle tracks?
There are 2 different types of subtitles people commonly call "forced", so clarification would help.
1- Subtitles which are displayed only to translate otherwise untranslated dialogue or on-screen text. I would prefer a better term than forced, but this is what "forced subtitles" correctly refers to.
2- Subtitles which always display and are not in the list of subtitle streams because they are "burnt-in" to the video. I found some people refer to these as forced subtitles but they are not forced, they are embedded in the video itself at which point they cannot be disabled or removed.
Which of those are you referring to?
Actually, it could also be default, not forced.
As an example, I found my media with separate subtitles files active those external subtitles by default when I play on some of my devices. I think VLC on my PC was 1 of them which auto-enables external sub files, but perhaps it is a setting I can change. I found VLC wonky with default/forced/external subtitles, where it would never play default or forced internal subs unless I selected them manually or set VLC's setting to default select subs (which caused it to *always* enable the 1st matching subtitle track), and it *always* enables external subtitles files forcing me to manually disable them each time the media begins playing.
The device/software you use to play media can definitely affect resulting display (or non-display) of subtitles, so it could be helpful to know your playback device & software.
Regarding solving the issue, I am not yet familiar enough with MakeMKV to know if it can "eliminate redundant forced subtitle tracks", but I would suggest trying MKVToolNix as a supplement.
Use MakeMKV to rip your media, use MKVToolNix to fix any resulting problems.
MKVToolNix does not transcode your MKV files, merely remuxes them, so it can VERY quickly alter MKV files.
Examples?
It can add audio or subtitle streams to an existing MKV file, or remove audio & subtitle streams from an MKV file, and it does it with almost no processing.
It can alter metadata of the MKV file, from altering display settings such as aspect ratios with no re-encoding to adding/altering stream information.
It can repair files processed by Handbrake. Yeah, I found Handbrake causes problems in resulting files. While they technically play correctly, it strips information from them such as stream bitrate & size, and somehow creates a larger file despite removing information. I use MediaInfo often to compare differences resulting from various settings in Handbrake, for example ensuring a re-encoded audio stream is not larger than the source. Files created by Handbrake lack the information to compare. MKVToolNix fixes the errors of Handbrake to restore the missing information so I can compare, and it somehow creates a smaller file solely by remuxing Handbrake's output.
Because MKVToolNix can add/remove streams/metadata from MKV files so quickly (as in seconds per GB of the file), I also let MakeMKV include more than I probably want because it is not clear which streams are what when you look at them in MakeMKV, but I can then use MKVToolNix to remove things like audio description streams (you know, where a person describes what is occurring on-screen?) or empty subtitle streams or (insert other thing I want removed here).
But know it must create a separate output file, not directly overwrite the source MKV, because it cannot read the source to remux to alter how you want if the output overwrites the source, so you need enough storage capacity to store input & output files but can delete the input when you are happy.
Examples?
flojo
Without remuxing/removing files, Matroska (.mkv/.mka) has 2 main flags that are editable with mkvpropedit that enable the playback of streams:
If forced_track is true (--set flag-forced=1) or default_track is true (--set flag-default=1) then the track should playback. If you set both to false, eg. --set flag-forced=0 --set flag-default=0, then the track should NOT playback, especially if it is a subtitle track (audio/video tracks vary based on player).
Assuming "movie.mkv" has track 1 as video, track 2 as audio, track 3 as SHD subtitles and track 4 as forced subtitles and I want to stop track 4 from displaying:
(to get the track number to use, use "mkvmerge -J movie.mkv", track indexing starts at 1, not 0)
If you just want to toggle default streams, mkvpropedit is the way to go, especially when filesizes become large since the operation takes ~0.5 seconds (although there is a deeper/longer scan for malformed .mkv's, but that's out of scope here).
"default_track": true,
"forced_track": false,
mkvpropedit --edit track:4 --set flag-forced=0 --set flag-default=0 movie.mkvIf you just want to toggle default streams, mkvpropedit is the way to go, especially when filesizes become large since the operation takes ~0.5 seconds (although there is a deeper/longer scan for malformed .mkv's, but that's out of scope here).
dyoung
You know, I think I found mkvpropedit years ago but completely forgot it existed. Thanks for mentioning it. 0.5 seconds to alter a few bits is definitely faster than using MakeMKV or MKVToolNix.flojo wrote: Sat Nov 09, 2024 9:14 pm If you just want to toggle default streams, mkvpropedit is the way to go, especially when filesizes become large since the operation takes ~0.5 seconds (although there is a deeper/longer scan for malformed .mkv's, but that's out of scope here).
Toad King
MKVToolNix can actually edit properties as well without remuxing. You just need to open the file in the "Header editor" section instead of the default "Multiplexer" section.dyoung wrote: Tue Nov 19, 2024 3:47 amYou know, I think I found mkvpropedit years ago but completely forgot it existed. Thanks for mentioning it. 0.5 seconds to alter a few bits is definitely faster than using MakeMKV or MKVToolNix.flojo wrote: Sat Nov 09, 2024 9:14 pm If you just want to toggle default streams, mkvpropedit is the way to go, especially when filesizes become large since the operation takes ~0.5 seconds (although there is a deeper/longer scan for malformed .mkv's, but that's out of scope here).
dyoung
Also good info so thanks for mentioning, but I found some other interesting info recently.Toad King wrote: Tue Nov 19, 2024 7:35 amMKVToolNix can actually edit properties as well without remuxing. You just need to open the file in the "Header editor" section instead of the default "Multiplexer" section.dyoung wrote: Tue Nov 19, 2024 3:47 amYou know, I think I found mkvpropedit years ago but completely forgot it existed. Thanks for mentioning it. 0.5 seconds to alter a few bits is definitely faster than using MakeMKV or MKVToolNix.flojo wrote: Sat Nov 09, 2024 9:14 pm If you just want to toggle default streams, mkvpropedit is the way to go, especially when filesizes become large since the operation takes ~0.5 seconds (although there is a deeper/longer scan for malformed .mkv's, but that's out of scope here).
I barely used MKVToolNix because honestly I avoided MKV files for a long time so had no need for it.
That was back when MKV files played poorly on all my devices and MP4 files were fully compatible with my devices & the streams in the files.
Ironically, switching from MP4 to MKV was delayed by what I think was a bug in an old version of Handbrake (I think 1.6.1) which allowed me to include all the latest audio streams, but I was unaware of the incompatibility between MP4 & new audio codecs until it stopped functioning, presumably because Handbrake fixed the bug allowing it which caused my transcoded files to be corrupt.
After that was when I learned of MP4 not being compatible with new audio codecs so began searching for an alternative and decided to try MKV again because MKV takes everything.
The Jellyfin server I installed a couple years ago handles MKV well and solves most issues, including live remuxing or transcoding when needed.
it also helped going to MKV because of needing MakeMKV, which also led me to MKVToolNix to fix some easy issues not requiring transcoding.
Now this is back to the reference because apparently MKVToolNix performs its header-only modification using mkvpropedit. XD
So that could be or is probably where I spotted it when I initially downloaded it a couple years ago, but I was not dealing with any of this the last 2-3 years so I forget if that was where.
Summary?
MKVToolNix quickly remuxes to add/remove streams in the file AND can modify header-only info faster by using the mkvpropedit.
