#10441 Post by RESET_9999 » Thu Nov 14, 2024 11:49 am
daffie wrote: Thu Nov 14, 2024 8:45 am Thanks for your help!
Do I need to use workflow 4-1 for this?
workflow 1
daffie
#10442 Post by daffie » Fri Nov 15, 2024 9:58 pm
RESET_9999 wrote: Thu Nov 14, 2024 11:49 am
workflow 1
Thanks alot. I managed to convert it to profile 8 and was able to watch it without problem!
LG OLED65G1RLA / Samsung HW-Q990D / Panasonic UB820 / Ugoos AM6B+ (CE with avdvplus Build)
TheEqualizer
#10443 Post by TheEqualizer » Mon Nov 18, 2024 5:08 am
About the movie Late Night with the Devil, I checked the new GBR edition, everything is fine with it, I'm doing a remux mkv 7 Profile.
Late Night with the Devil_scene-cuts.txt
(8.67 KiB) Downloaded 773 times
EL_Late Night with the Devil_scene-cuts.txt
(8.67 KiB) Downloaded 761 times
darrrkmanxxx
#10444 Post by darrrkmanxxx » Mon Nov 18, 2024 12:47 pm
ans40 wrote: Mon Oct 21, 2024 9:31 pm
Jimbo21 wrote: Mon Oct 21, 2024 9:31 am Hi all
Does anyone know if there is a Mac app that converts HDR10+ to Dolby Vision?
Have used Nekno's "DV7 to DV8" MacOS app (as the name implies, to convert DV7 to DV8). It works well. But am trying to find something for HDR10+ to DV. Have seen Reset's DoVi scripts, but unfortunately don't have Windows.
I'm not sure about Mac options, but you could use the tools with a Windows virtual machine, too.
sorry late to the party but you can do everything on macos, besides the madvr measureing.
- extract hevc file from the container with Tsmuxer
- extract the hdr10+ json from the hevc with: https://github.com/quietvoid/hdr10plus_tool
- convert to dvp8 rpu with: https://github.com/quietvoid/dovi_tool look for From an existing HDR10+ metadata JSON file
- adjust CMv4.0 and L5 Active area if not OpenMatte, see https://github.com/quietvoid/dovi_tool look for editor with data from MedIaInfo (see Mastering display luminance etc.)
- mux back the new dvp8.hevc files into the container with MKVToolsnix
hdr10plus_tool, dovi_tool, MKVToolnix and TsMuxeR are working native on macOS
ColonelBlimp043
#10445 Post by ColonelBlimp043 » Wed Nov 20, 2024 8:43 pm
If I run 3-1 to generate a new RPU for a profile 7 FEL MKV with static metadata, will the FEL be analyzed together with the BL by CM Analyzer?
I tried bake encoding the BL+FEL into a ProRes .mov with 8-2 and then running 3-1 on the resulting ProRes .mov, but I received an error message that the ProRes file was not HDR.
#10446 Post by RESET_9999 » Wed Nov 20, 2024 9:19 pm
No, 3-1 doesnt bake FEL.
You'll probably have to provide the shot list. If the original static RPU has proper scene cuts, just rename it the same as your prores file and try 3-1 again.
If the original has no scene cut, you can try to add ''transfer=hdr matrix=2020'' in your prores filename but I'm not sure if generating new scene cuts for FEL is right because of the reshaping metadata.
ColonelBlimp043
#10447 Post by ColonelBlimp043 » Wed Nov 20, 2024 10:51 pm
Thanks. Even if I successfully run 3-1 on the baked pro-res file, though, is there any way to inject the generated RPU into the original profile 7 FEL mkv? As I understand workflow 1’s inject function, it would discard the FEL video track and create a profile 8 mkv with the BL and new rpu.
Essentially, I want to mux the new rpu with original BL and EL video tracks.
#10448 Post by RESET_9999 » Wed Nov 20, 2024 11:01 pm
You have to transfer the generated metadata levels to the original P7 RPU with workflow 2-3. You'll have to transfer levels 12389 but you may have to transfer 12 and then 389(I'm not sure if 12389 will work).
If you didn't use the original scene cuts, you have to transfer them too but as I said earlier I'm not sure it is right to change the original FEL scene cuts.
Then you can inject the new P7 RPU to the original P7 mkv rip with workflow 1
ColonelBlimp043
#10449 Post by ColonelBlimp043 » Wed Nov 20, 2024 11:25 pm
Thanks. I genuinely appreciate the help. This is only a problem on a handful of FEL rips with static/missing metadata. Criterion seems to be the worst offender as a publisher, and the recent Cameron releases also have static trims. Thankfully they all seem to be mastered at low nit levels and don’t use the FEL to raise brightness, so this may all be academic.
#10450 Post by RESET_9999 » Tue Nov 26, 2024 3:55 pm
RESET_9999 wrote: Sat Nov 09, 2024 1:50 pm anyway the problem is the EL and german discs
I wonder if all the French UHD-BD should be verified now. It looks like Blade 1998 FEL FRA BD has the same issue :(
https://slow.pics/c/YzYgHn4x
jayper
#10451 Post by jayper » Tue Nov 26, 2024 4:43 pm
RESET_9999 wrote: Tue Nov 26, 2024 3:55 pm
So, to be clear, is this a disc mastering issue? A MakeMKV issue? Or a combination?
Sorry to be late on this. What's the best way to verify our backups? Thanks!
#10452 Post by RESET_9999 » Tue Nov 26, 2024 4:54 pm
It's a disc authoring/encoding issue.
To verify your makemkv rip, just extract the RPU, info/plot it with dovi_tool, and check if the framecount matches the video.
jayper
#10453 Post by jayper » Tue Nov 26, 2024 4:55 pm
RESET_9999 wrote: Tue Nov 26, 2024 4:54 pm It's a disc authoring/encoding issue.
Thanks so much! Much appreciated.
#10454 Post by RESET_9999 » Tue Nov 26, 2024 6:07 pm
PS: I added a new tab to my Excel sheet for the problematic discs:
https://docs.google.com/spreadsheets/d/ ... 2109165913
DiscoD
#10455 Post by DiscoD » Wed Nov 27, 2024 5:32 pm
Is there a setting somewhere i can change to save the log file of the entire process when i run 8-2-1.
i would like to save it to a txt file if possible in the same folder.
