Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Re: Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
#31 Post by Coopervid » Sun Nov 17, 2024 5:59 pm
pipo233 wrote: Sun Nov 17, 2024 4:40 pm i have a pioneer S09 with this info:
Is it possible to flash it to read UHD?
if so how can i get a flasher?
You have a PM.
pipo233
#32 Post by pipo233 » Sun Nov 17, 2024 8:03 pm
Thanks coopervid, it works perfectly, it now reads UHD
pipo233
#33 Post by pipo233 » Sun Nov 17, 2024 8:32 pm
I have jet another drive, pioneer bdr-209M
Can this one be flashed to read UHD?
#34 Post by Billycar11 » Sun Nov 17, 2024 11:13 pm
See below email me I have a flasher for it
lSPk7WduqTfsShca
#35 Post by lSPk7WduqTfsShca » Tue Nov 19, 2024 9:38 am
Coopervid wrote: Sun Oct 27, 2024 10:00 am
tom25 wrote: Sat Oct 26, 2024 4:57 pm Hello everyone,
I also have a Pioneer BDR-S09.
Is my Pioneer suitable for flashing for UHD reading?
PM sent.
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-S12
Revision: 1.01
Serial number: [REMOVED]
Firmware date: 2020-07-21
Highest AACS version: 76
Drive platform: RS8F00
Firmware version: 1.01/ID45
Is this drive possible for UHD?
#36 Post by Coopervid » Tue Nov 19, 2024 2:12 pm
lSPk7WduqTfsShca wrote: Tue Nov 19, 2024 9:38 am
PM sent.
OS device name: E:
Revision: 1.01
You have a second PM.
chrisw
#37 Post by chrisw » Wed Nov 20, 2024 6:59 pm
Hello, longtime lurker, first time poster ;) I also saved one of these drives from a machine which was being WEEEd - MFD is June 2015 so I presume it'll still be on the original FW (S/N begins 0FDL017). I presume this will also need a firmware patch?
Also if there are tools for dumping FW for these models of drives, would anyone have any use for this drive's original FW? If so, happy to donate.
#38 Post by Coopervid » Wed Nov 20, 2024 7:42 pm
chrisw wrote: Wed Nov 20, 2024 6:59 pm Hello, longtime lurker, first time poster ;) I also saved one of these drives from a machine which was being WEEEd - MFD is June 2015 so I presume it'll still be on the original FW (S/N begins 0FDL017). I presume this will also need a firmware patch?
You need to post your Makemkv info to get help.
chrisw
#39 Post by chrisw » Wed Nov 20, 2024 11:22 pm
Coopervid wrote: Wed Nov 20, 2024 7:42 pm
Sorry, was trying to avoid spamming the thread - see below (with a random BD inserted for testing). Playback is fine in MPC-HC/VLC using Passkey, I've not been able to test rip in MakeMKV yet as it's showing an error about the evaluation period having expired.
Product: BD-RW BDR-S09
Revision: 1.30
Serial number: OFDL01****WL
Firmware date: 2014-12-05
Highest AACS version: 23
Drive platform: RS8600
Firmware version: 1.30/ID43
Disc Information
Label: MICMACS
Timestamp: 2010-05-11 16:10:18
Protection: AACS v17
Data capacity: 19.91 Gb
Disc type: BD-ROM
Number of layers: 1
I've also recently unearthed a BDR-XD07TUHD (toploader USB3 drive) which purports to be UHD compatible but I've not had the means to test that yet.
lSPk7WduqTfsShca
#40 Post by lSPk7WduqTfsShca » Thu Nov 21, 2024 7:10 am
1.
Drive information
Operating system device name: g:
Product: BD-RW BDR-209D
Revision: 1.51
Serial number:
Firmware Date: May 8, 2018
Bus encryption identifier: 13
LibreDrive information
Drive platform: RS8601
Firmware type: original (no patch applied)
Firmware version: 1.51/ID61
DVD full area: yes
BD raw data reading: Yes
BD original metadata reading: Yes
Unlimited reading speed: Yes
2.
Drive information
Revision: 1.52
Serial number:
Firmware Date: January 11, 2019
Bus encryption identifier: 1B
Firmware version: 1.52/ID43
DVD full area: yes
3.
Drive information
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number:
Firmware Date: December 21, 2017
Firmware version: E114/ID71
DVD full area: yes
4.
Drive information
Product: BD-RW BDR-208D
Revision: 1.10
Serial number:
Firmware Date: August 22, 2012
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: 1.10/ID61
DVD full area: yes
5.
Drive information
Product: BD-RW BDR-S08
Revision: 1.10
Serial number:
Firmware Date: August 28, 2012
Firmware version: 1.10/ID43
DVD full area: yes
So basically some 209s and some 208s
#41 Post by Coopervid » Thu Nov 21, 2024 11:49 am
chrisw wrote: Wed Nov 20, 2024 11:22 pm
Revision: 1.30
Disc Information
Label: MICMACS
Disc type: BD-ROM
Number of layers: 1
PM sent. For the XD07 you also need to post your Makemkv info.
#42 Post by Coopervid » Thu Nov 21, 2024 11:52 am
lSPk7WduqTfsShca wrote: Thu Nov 21, 2024 7:10 am 1.
Drive information
Revision: 1.51
Serial number:
DVD full area: yes
2.
Drive information
Revision: 1.52
Serial number:
DVD full area: yes
3.
Drive information
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number:
DVD full area: yes
4.
Drive information
Revision: 1.10
Serial number:
DVD full area: yes
5.
Drive information
Revision: 1.10
Serial number:
DVD full area: yes
You have 2 PMs.
chrisw
#43 Post by chrisw » Fri Nov 22, 2024 1:40 am
Coopervid wrote: Thu Nov 21, 2024 11:49 am
Revision: 1.30
Disc Information
Label: MICMACS
Disc type: BD-ROM
Number of layers: 1
Appreciate it! Checked out the PM, process worked flawlessly and the UHD discs seem to be readable now. Amazing how effortless it was.
An interesting side-effect appears to be that something's happened to DVDFab Passkey, which I would sometimes use for playing back BDs on the machine through MPC-HC (bitstreaming the audio and HDR signal via MadVR). It previously worked fine, but now it seems to consistently crash while trying to initialise. Is this just a side-effect of the process or would you expect Passkey to still work?
lSPk7WduqTfsShca
#44 Post by lSPk7WduqTfsShca » Fri Nov 22, 2024 2:11 am
The following two would be 211 v2, I suppose?
6.
OS device name: E:
Revision: 1.31
Serial number:
Firmware date: 2015-05-25
Firmware version: 1.31/ID43
OS device name: E:
Revision: 1.51
Serial number:
Firmware date: 2018-05-08
Firmware version: 1.51/ID43
#45 Post by Billycar11 » Fri Nov 22, 2024 4:09 am
lSPk7WduqTfsShca wrote: Fri Nov 22, 2024 2:11 am The following two would be 211 v2, I suppose?
6.
OS device name: E:
Revision: 1.31
Serial number:
OS device name: E:
Revision: 1.51
Serial number:
my flasher figures all that out for you automatically fyi
