Greetings,
MKB20_v77_The_Terminator_(1984)_A7C2 Submitted.
Dump Submitted for The Terminator
keydb_helper
Re: Dump Submitted for The Terminator
The A7C2 release of The Terminator has been added to the public keydb. It should support your disc.
Public KeyDB Disc Submissions
- LG/Buffalo/Asus drives only (Pioneer drives are not supported)
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
Sweet waiting for this one myself.
Sent from my SM-S928U1 using Tapatalk
CrashDavis88
Still not working A7C2 this morning. Tried two different drives. Dumps submitted.
polskasubie
this works with the newest keydb file
My UK copy ripped fine.
CrashDavis88
It's dead for me. US Steelbook.
MakeMKV v1.17.8 win(x64-release) started
Downloading latest SDF to C:/temp/Rip ...
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Downloading latest HK to C:/temp/Rip ...
Saved AACS dump file as C:/temp/Rip/MKB20_v77_The_Terminator_(1984)_A7C2.tgz
keydb_helper
Hey CrashDavis88, are you using the public keydb file? If not, you'll need to wait until MakeMKV has native support for The Terminator.CrashDavis88 wrote: ↑Mon Nov 18, 2024 9:28 pmIt's dead for me. US Steelbook.
If you'd like to decrypt your disc right away I've detailed how to download and setup the public keydb here
CrashDavis88
Thank you all! Good to go here now, not sure what was wrong but it started working almost 30 mins after I posted my last post.
