ASUS SBW-06D2X-U
Re: ASUS SBW-06D2X-U
#61 Post by Coopervid » Mon Oct 07, 2024 7:45 pm
dihjaskd wrote: Mon Oct 07, 2024 5:34 pm I run a:
OS device name: E:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: <redacted>
Firmware date: 2017-04-18
Highest AACS version: 68
Firmware version: ID22
Is there a way to make it libredrive friendly ?
Fixed.
keaney2023
#62 Post by keaney2023 » Mon Oct 21, 2024 1:57 pm
Hi looking for confirmation if i can use the BU40N on my drive:
Manufacturer: ASUS
Revision: 1.10
Serial number: redacted
#63 Post by Coopervid » Mon Oct 21, 2024 3:04 pm
keaney2023 wrote: Mon Oct 21, 2024 1:57 pm Hi looking for confirmation if i can use the BU40N on my drive:
Manufacturer: ASUS
Revision: 1.10
No. Read your PM.
msteiiin
#64 Post by msteiiin » Tue Nov 05, 2024 6:21 pm
Is it possible to flash this drive to be able to read UHD Blurays?
Manufacturer: ASUS
Revision: A102
Serial number: [redacted]
Firmware date: 2121-06-28 13:41
Bus encryption flags: 1F
Highest AACS version: 62
I didn't know about this UHD stuff and bought the only Bluray burner in the store.
Actually ... the firmware date looks weired.
Farinhir
#65 Post by Farinhir » Fri Nov 15, 2024 3:18 am
I am trying to upgrade my Asus drive I have had for years also. I am not unfamiliar with flashing. I am looking for the correct tool and target firmware.
Thank you.
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Serial number: [Redacted]
Highest AACS version: 77
#66 Post by Coopervid » Sun Nov 17, 2024 10:37 am
msteiiin wrote: Tue Nov 05, 2024 6:21 pm Is it possible to flash this drive to be able to read UHD Blurays?
Manufacturer: ASUS
Revision: A102
Read this:
viewtopic.php?f=16&t=19634
#67 Post by Coopervid » Sun Nov 17, 2024 10:38 am
Farinhir wrote: Fri Nov 15, 2024 3:18 am I am trying to upgrade my Asus drive I have had for years also. I am not unfamiliar with flashing. I am looking for the correct tool and target firmware.
Thank you.
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
PM is on its way.
Farinhir
#68 Post by Farinhir » Sun Nov 17, 2024 12:51 pm
Thank you so very much, Coopervid. I just tested and it works flawlessly.
Kudo417
#69 Post by Kudo417 » Thu Nov 28, 2024 1:42 am
Based on the other posts in this thread, I think this should be able to be flashed to support UHD, correct?
OS device name: \Device\CdRom2
Manufacturer: ASUS
Revision: 1.10
Highest AACS version: 61
#70 Post by Coopervid » Thu Nov 28, 2024 10:06 am
Kudo417 wrote: Thu Nov 28, 2024 1:42 am Based on the other posts in this thread, I think this should be able to be flashed to support UHD, correct?
Manufacturer: ASUS
Revision: 1.10
PM sent.
WildInsignia
#71 Post by WildInsignia » Mon Dec 02, 2024 4:05 am
Good Evening All, I have same model Drive and i was trying to see which f/w i would flash, I have downloaded the asus flasher and the f/w pack..just dont know which one to use.
OS device name: H:
Manufacturer: ASUS
Revision: 1.10
Also wondering the fact that it says "Drive platform: Pioneer RS8511" dose that mean that its a Pioneer drive?
Thank you for any help.
#72 Post by MartyMcNuts » Mon Dec 02, 2024 9:03 pm
WildInsignia wrote: Mon Dec 02, 2024 4:05 am Good Evening All, I have same model Drive and i was trying to see which f/w i would flash, I have downloaded the asus flasher and the f/w pack..just dont know which one to use.
OS device name: H:
Manufacturer: ASUS
Revision: 1.10
Yes, it's a Pioneer drive. The old Asus flasher isn't compatible.
WildInsignia
#73 Post by WildInsignia » Mon Dec 02, 2024 11:19 pm
MartyMcNuts wrote: Mon Dec 02, 2024 9:03 pm
OS device name: H:
Manufacturer: ASUS
Revision: 1.10
So with that, i would have to use another flasher then?
#74 Post by MartyMcNuts » Tue Dec 03, 2024 1:21 am
WildInsignia wrote: Mon Dec 02, 2024 11:19 pm
OS device name: H:
Manufacturer: ASUS
Revision: 1.10
There is no public flasher tool available for Pioneer drives. You could try contacting Billycar11. He may be able to do something for you.
brezler2
#75 Post by brezler2 » Tue Dec 10, 2024 6:21 pm
could you help me out on that one? Thank you!
Aktuelles Profil: BD-ROM
Produzent: ASUS
Produkt: SBW-06D2X-U
Revision: 1.10
Serienummer: [redacted]
Firmware-Datum: 2017-04-18
Highest AACS version: 70
