Drive won't work on Debian
Mewiimii
Post by Mewiimii »
I have a LG GH22NS50. It works flawlessly on windows. It does not work on Debian. Makemkv recongnizes the drive, but when I pop in the disc, Makemkv goes into an infinite loop. Debian can open the video and playback is flawless. I can rip the .ISO using the disks program on Debian, but that is less than ideal. Attached is a photo the drive information in windows.
disc drive.png (34.39 KiB) Viewed 6068 times
Mewiimii
Re: Drive won't work on Debian
Post by Mewiimii »
I reinstalled makemkv through the snap command. In the settings app under applications, the new install had the slider option to allow read-write and other settings. I enabled them all and that fixed it.
Is there any way to have makemkv have this menu by standard without having to go through snap to install? Is there a set of commands to enable the same permissions for other users experiencing the same issues?
cokers
Post by cokers »
To obtain a permission settings menu similar to that in Snap installations in standard MakeMKV installations, you can try using other package management methods such as flatpak or AppImage to install MakeMKV. These methods may provide functionality similar to permission settings in Snap.
flojo
Post by flojo »
Mewiimii wrote: Fri Nov 15, 2024 5:52 pm ...on Debian.
...without having to go through snap to install?
Debian is not Ubuntu.
No, this is part of containerization. If the contained program itself could decide to write to the root FS, then there would be no point. Effectively you're wanting to give the jail keys to the prisoner.
Mewiimii
Post by Mewiimii »
flojo wrote: Sat Nov 16, 2024 3:08 pm
No, this is part of containerization. ... Effectively you're wanting to give the jail keys to the prisoner.
Yes, I am using debian, not Ubuntu.
How how do you get the slider settings in the GUI menu following the standard installation process or what are the CLI commands to enable the necessary drive permissions?
prahal
Post by prahal »
Do you mean in your first unsuccessful attempt, you installed makemkv as a deb package?
Mind if a program is installed as a deb there are no switches to turn on to give the container access because there is no container (be it snap, flatpak, etc). If you can play the dvd from the drive it means your user already have access to the drive (and debs have the access of the current user).
You should give errors from makemkv (the deb install) if you want us to help you with the deb install.
makemkv logs are in $HOME/MakeMKV_log.txt
Also in Makemkv View > Settings : General tab "Miscellaneous" check "Log debug messages", these messages will appear in the MakeMKV_log.txt file
PS: mind, I am using makemkv deb on Debian. From https://apt.benthetechguy.net/ (though lately I modified this package to up the code to 1.17.8 with one local hack)
