Hi there MakeMKV community!
Longtime user of the Windows version, switched to Linux out of MS frustration a few weeks back (been using Linux for years); bought a replacement Asus drive, brand new, connected it, built MakeMKV from source, inserted a blu-ray, started MakeMKV and it... hung at "Scanning for CD-Rom drives".
(This is on a registered, paid copy of MakeMKV, same key as I've been using on Windows for a few years).
Ejected the disk, cleared all makemkvcon processes, relaunched MakeMKV, it started fine, detected the drive, found all of its specs, all good.
Put a disc back in, restarted MakeMKV -- same hang.
Tried with Makemkvcon -- hangs at first line.
Disc itself opens up fine and can be navigated easily within file manager and command prompt (so Linux sees the /dev/sr0 device just fines and grants my user access to it just fine). Used the CD-Rom functionality of the drive to copy over 300+megs of data in the same session, so drive is just fine.
Which leaves me at : MakeMKV hangs with a blu-ray disc inserted in the drive, never terminating, leaving a hanging makemkvcon process behind.
I guess my first step would be debug logging on, or is there something else I can try to unblock it?
1.17.8 hangs when trying to read from brand new Asus SDW-06D2X
whitenoise
LordKaladar
Re: 1.17.8 hangs when trying to read from brand new Asus SDW-06D2X
Having a very similar issue, but with a PIONEER BDR-XD08U under Kubuntu.
Very hopeful someone has info for you (and potentially me).
I am able to close MakeMKV. I don't see the processes staying behind. I basically just get "Disc is being Loaded" indefinitely.
gpshumway
I'm having this issue as well. Though I've seen a few different manifestations of issue while trying to get MakeMKV working on my new Linux box. My first issue (on Fedora 41) was that MakeMKV wouldn't proceed beyond downloading SDF:
viewtopic.php?f=3&t=35703
Now I've got it installed in a Debian 12 install and initially it would launch with almost every button grayed out, including the "Register" button.
I got MakeMKV to un-gray the buttons, accept my registration code and start reading the drive, but then it hangs. Exhibiting exactly the behavior detailed by the OP.
My system is:
Debian 12
LG HL-DT-ST BD-RE WH16NS40 (1.04) Blu-Ray drive
AMD Ryzen 8600G in an MSI B650 motherboard
The MakeMKV debug file shows:
Thanks for any help!
My system is:
Debian 12
Debug log started at Wed Nov 13 02:00:33 2024 , written by MakeMKV v1.17.8 linux(x64-release)
001005:0000 MakeMKV v1.17.8 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///home/mcfly/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.88.1/OpenSSL/3.0.15/1.52.0 (x86_64-pc-linux-gnu) , proxy server not set.
001003:0020 DEBUG: Code 0 at }jexA76La`JjTu9fehtZ;%:29393631
No SDF v098: HL-DT-ST_BD-RE__WH16NS40_1.04_211901041348_KLZJASJ4347
SDF auto v098: HL-DT-ST_BD-RE__WH16NS40_1.04_211901041348_KLZJASJ4347-
Djoss
I'm also seeing this problem.
Just listing the drives via makemkvcon is enough to make it hang:
makemkvcon -r --cache=1 info disc:9999-
fosskers
Hey folks, I'm having the same issue, and it seems like a lot of people are. This post seems to have the most information: viewtopic.php?f=3&t=35703
In particular, `makemkvcon` is being started up with the `guiserver` command, even when ran from the console, and this process hangs at 100%. Note that this affects any other command that tries to call to `makemkvcon`, like `bd_info` or VLC.
wmcclain
Same here. 1.17.8 and .9 hang when trying open both Blu-ray and DVD discs. I'm not using UHD.
This is with both a SATA ASUS drive and and a USB Pioneer.
1.17.7 works.
1.17.7 works.
BandoMan
This is definitely an issue with 1.17.8 and 1.17.9. 1.17.7 works. This is not a linux issue, because it is the same on windows 11. This is with both a SATA ASUS and a USB LG. I'm on linux mint, here is a "temporary solution that works for me": (This adds the makemkv repo, install 1.17.9 for updated libs to match updated ffmpeg, then downgrades to 1.17.7)
It should work, you might not need to install 1.17.9, and just start with the wget command, or visit: https://www.makemkv.com/download/old/
However, my ffmpeg version needed MakeMKV's latest libraries.
!/bin/bash
# Install 1.17.9
sudo add-apt-repository ppa:heyarje/makemkv-beta
sudo apt update
sudo apt install makemkv-bin makemkv-oss
read -p "Register your key, then close MakeMKV, (Press ENTER)"
makemkv
# Downgrade to 1.17.7
wget https://www.makemkv.com/download/old/makemkv-bin-1.17.7.tar.gz
gunzip makemkv-bin-1.17.7.tar.gz
tar -xvf makemkv-bin-1.17.7.tar
cd makemkv-bin-1.17.7
echo "q" | make
# Type "yes" here
sudo make install
flojo
This does _NOT_ "fix the issue" with 1.17.8/9.
BandoMan
Fixed.This does _NOT_ "fix the issue" with 1.17.8/9.
