Pioneer BDR-UD03 UHD possibility
RogerRabbit
Re: Pioneer BDR-UD03 UHD possibility
Post by RogerRabbit » Sat Nov 16, 2024 4:55 pm
Hi Coopervid,
Can you send me the flash instructions for this drive/config, so it can read UHD discs? It's a pioneer drive in a Verbatim housing.
RR.
OS device name: L:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.11
Serial number: xxxxx
Firmware date: 2018-11-28
Highest AACS version: 23
Drive platform: RS8511
Firmware version: 1.11
DiXY___
Post by DiXY___ » Sat Nov 16, 2024 7:33 pm
OS device name: E:
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Firmware version: 1.14
Hi @Coopervid Can you help me as well with my drive? Thanks in advanced!
DiXY___
Post by DiXY___ » Sat Nov 16, 2024 7:45 pm
OS device name: E:
Revision: 1.14
Post by Coopervid » Sat Nov 16, 2024 8:27 pm
RogerRabbit wrote: Sat Nov 16, 2024 4:55 pm Hi Coopervid,
RR.
OS device name: L:
Revision: 1.11
PM is comimg.
Post by Coopervid » Sat Nov 16, 2024 8:28 pm
DiXY___ wrote: Sat Nov 16, 2024 7:45 pm
OS device name: E:
Revision: 1.14
PM is on its way.
DiXY___
Post by DiXY___ » Sat Nov 16, 2024 8:59 pm
Coopervid wrote: Sat Nov 16, 2024 8:28 pm PM is on its way.
amazing! just works many thanks
Vedder9
Post by Vedder9 » Sat Nov 16, 2024 10:30 pm
Hey, @Coopervid
Seems you are the one to turn to. Any way you'd be able to work your magic yet again?
Revision: 1.14
Post by Coopervid » Sun Nov 17, 2024 10:25 am
Vedder9 wrote: Sat Nov 16, 2024 10:30 pm Hey, @Coopervid
Revision: 1.14
PM sent.
ravix
Post by ravix » Mon Nov 18, 2024 8:25 pm
<Accidental double post (see next) >
ravix
Post by ravix » Mon Nov 18, 2024 8:36 pm
Revision: 1.14
Hey @Coopervid, I am in the same boat. I got the drive above and I'm looking for a firmware image. Can you help? Thanks!
(By the way, I just posted this once already before but I didn't see the post appear. I'm trying again and hope I'm not accidentally double posting)
Post by Coopervid » Mon Nov 18, 2024 9:34 pm
ravix wrote: Mon Nov 18, 2024 8:36 pm
Revision: 1.14
PM sent.
ravix
Post by ravix » Mon Nov 18, 2024 10:23 pm
@Coopervid: I followed the tutorial and it worked great. Thanks!
daiden
Post by daiden » Wed Nov 20, 2024 5:23 pm
I recently got one of these as well:
Any chance I could get the firmware as well?
Post by Coopervid » Wed Nov 20, 2024 5:47 pm
daiden wrote: Wed Nov 20, 2024 5:23 pm I recently got one of these as well:
Sure. Check your PM.
daiden
Post by daiden » Thu Nov 21, 2024 6:24 pm
Thank you. I followed the steps, but it seems like the drive can't read any discs that I try (both blu ray and uhd). It'll make loading sounds for a bit and then display "No disc inserted" in makemkv.
OS device name: F:
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: [removed]
Drive platform: RS8A10
Anyone experience this and know a fix?
