LibreDrive for Pioneer drives
lord_farfig
#1126 Post by lord_farfig » Tue Nov 05, 2024 11:15 pm
Coopervid wrote: Tue Nov 05, 2024 10:15 pm PM sent.
Thank you!
I have updated the firmware and can confirm the drive now works in Linux without issue!
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: ADDL211420WL
Firmware date: 2020-06-15
Highest AACS version: 68
Drive platform: RS8A10
Firmware version: 1.14
Erestor
#1127 Post by Erestor » Tue Nov 12, 2024 4:43 pm
I could need some help with this drive if possible. :mrgreen:
Product: BD-RW BDR-S09
Revision: 1.50
Firmware date: 2017-12-21
Highest AACS version: 81
Drive platform: Pioneer RS8601
Firmware version: ID43
Drive Information:
Model Name : PIONEER BD-RW BDR-S09
Firmware Rev : 1.50
Extra Info : 17/12/21
Buffer Size : 4000 kiB
Additional Drive Information:
Label Code : ----
Hardware Rev : SAT 8601
Kernel Type : ID43
Firmware Type : ID43
Kernel Version : 0000
Drive is in normal mode.
Firmware flashing support : NO
Firmware dumping support : NO
Drive Capabilities:
CD-ROM : R BD-ROM : R
CD-R : R/W BD-R : R/W
CD-RW : R/W BD-R XL : R/W
DVD-ROM : R BD-RE : R/W
DVD-R : R/W BD-RE XL : R/W
DVD-R DL : R/W HD DVD-ROM : -
DVD-RW : R/W HD DVD-R : -
DVD+R : R/W HD DVD-R DL : -
DVD+R DL : R/W HD DVD-RW : -
DVD+RW : R/W LabelFlash : NO
DVD-RAM : R/W LightScribe : NO
#1128 Post by Billycar11 » Tue Nov 12, 2024 9:07 pm
Erestor wrote: Tue Nov 12, 2024 4:43 pm I could need some help with this drive if possible. :mrgreen:
Revision: 1.50
yeah email me see below
mrblakjack
#1129 Post by mrblakjack » Thu Nov 14, 2024 3:23 am
The link is broke, from where can I download the file ?
TheResoluteHawk
#1130 Post by TheResoluteHawk » Fri Nov 15, 2024 5:21 pm
Hi! Just received an XS07B-UHD and I think I may have posted this to the wrong thread. Here is my MakeMKV information.
Product: BD-RW BDR-XS07U
Revision: 1.00
Serial number: redacted
Firmware date: 2019-01-07
Firmware version: ID69
I also went into the MakeMKV log file and took this info down. I don't know if it means that the drive has to be added to a configuration file somewhere, but here it is just in case.
Debug log started at Fri Nov 15 18:15:50 2024 , written by MakeMKV v1.17.8 win(x64-release)
001005:0000 MakeMKV v1.17.8 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\User/MakeMKV_log.txt
Using 262272KB for read cache
No SDF v098: PIONEER_BD-RW_BDR-XS07U_1.00_TEDL007250JP
DEBUG: Code 3 at E}P)4^&Zt'eI2]i`NTMR>^^t:29395310
SDF id v098: PIONEER_BD-RW__BDR-XS07U_1.00_TEDL006250JP
Application exited at Fri Nov 15 18:16:54 2024
#1131 Post by Coopervid » Fri Nov 15, 2024 7:11 pm
TheResoluteHawk wrote: Fri Nov 15, 2024 5:21 pm Hi! Just received an XS07B-UHD and I think I may have posted this to the wrong thread. Here is my MakeMKV information.
Revision: 1.00
Read your PM.
TheResoluteHawk
#1132 Post by TheResoluteHawk » Fri Nov 15, 2024 7:27 pm
Thanks for the quick reply!
Worked like a charm.
Nizmo553
#1133 Post by Nizmo553 » Sun Nov 17, 2024 5:07 am
Hi I could use some help with this drive, I can rip normal blurays but ripping 4kUHD ones cause errors
OS device name: G:
Product: BD-RW BDR-XD08U
Revision: 1.02
Firmware date: 2022-12-27
Highest AACS version: 78
Drive platform: Pioneer RS9331
Firmware version: ID05
#1134 Post by Billycar11 » Sun Nov 17, 2024 10:33 am
Nizmo553 wrote: Sun Nov 17, 2024 5:07 am Hi I could use some help with this drive, I can rip normal blurays but ripping 4kUHD ones cause errors
OS device name: G:
Revision: 1.02
sorry man fw is too new can do UHD return it if you can
and buy from a seller in your region that has pioneers with old fw
bdjump2711
#1135 Post by bdjump2711 » Mon Nov 18, 2024 11:28 am
Hi!
Im fairly new to the topic and also this forum...
In the initial post of this topic, it is stated that the BDR-207 drives from pioneer would likely stay unsupported. I have such a device and would like to know if there is anything I could help with to make this drive supported for UHD BluRays (normal DVD and BluRays work like a charm tho). It is a Pioneer BDR-207EBK with very old firmware and should be Triple-Layer BD compatible, at least it's got the BdXL mark on it.
This is whats reported by makemkv about it.
OS device name: E:
Product: BD-RW BDR-207M
Revision: 1.21
Serial number: XXXXXXXXX
Firmware date: 2012-03-27
Bus encryption flags: 13
Status: Possible, but very unlikely to happen
Drive platform: Pioneer RS8000
Firmware version: ID60
And thats the debug log info if it is helpful:
Debug log started at Mon Nov 18 11:20:51 2024 , written by MakeMKV v1.17.8 win(x64-release)
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\xxxx/MakeMKV_log.txt
No  SDF v098: PIONEER_BD-RW___BDR-207M_1.21_LHDL020202WL
SDF id v098: PIONEER_BD-RW___BDR-207M_1.21_LHDL020202WL
Application exited at Mon Nov 18 11:21:06 2024
#1136 Post by Billycar11 » Mon Nov 18, 2024 12:04 pm
bdjump2711 wrote: Mon Nov 18, 2024 11:28 am Hi!
nah 208 or newer sorry
bdjump2711
#1137 Post by bdjump2711 » Mon Nov 18, 2024 1:41 pm
Okay, thx for the quick look anyway
lSPk7WduqTfsShca
#1138 Post by lSPk7WduqTfsShca » Tue Nov 19, 2024 9:48 am
OS device name: E:
Product: BD-RW BDR-S12
Revision: 1.01
Serial number: [removed]
Firmware date: 2020-07-21
Highest AACS version: 76
Drive platform: RS8F00
Firmware version: 1.01/ID45
It is not reading UHD discs
#1139 Post by Coopervid » Tue Nov 19, 2024 1:04 pm
lSPk7WduqTfsShca wrote: Tue Nov 19, 2024 9:48 am Drive Information
OS device name: E:
Revision: 1.01
It can't yet. Read your PM.
cwiggles
#1140 Post by cwiggles » Wed Nov 20, 2024 9:04 am
Revision: 1.03
Serial number: CHDL007735WL
Firmware date: 2023-01-06
