Feature Request: Eject button
120FPS
Post by 120FPS » Fri Nov 15, 2024 2:33 pm
I was wondering if adding a feature whereby the eject button on MakeMKV could open AND close. It would just make it easier for those using a computer in another room, instead I have to run over and do it manually. Not sure if it's possible but it would be very convenient indeed.
Thank you to the dev/s for all the work you have done.
Ezatoka
Re: Feature Request: Eject button
Post by Ezatoka » Fri Nov 15, 2024 5:04 pm
So you're running into another room, place a disc into the open tray, then go back and want the software to close the tray instead of just giving it a slight nudge while you're there anyway? (never hurt my drive in many years so far, if someone wants to comment on that. Plus there's still the open/close button on the drive.)
120FPS
Post by 120FPS » Fri Nov 15, 2024 10:31 pm
The macOS version of MakeMKV has a couple of quirks (for me at least, it ejects the disk if I put a new one in sometimes), which means I have to run back and forth to open and close the drive for the same disc.
chrisb42
Post by chrisb42 » Tue Nov 19, 2024 3:15 pm
You can have an eject button in the menu bar when you turn on "Show eject in menu bar" in System Settings -> CDs & DVDs. That allows you open and close any attached optical drive.
