Ekontos
Re: SDFtool Flasher Problem
Post by Ekontos »
My drive info. It is an LG BP60NB10. It looks like it flashed successfully. I used this bin: DE_LG_BP60NB10-NB12_1.02-MK.bin
Product: BD-RE BP60NB10
Revision: 1.02
Serial number:
Firmware date: 2121-07-08 15:56
Highest AACS version: 76
Firmware version: 1.02
Disc Information
Label: SNATCH
Timestamp: 2021-04-22 18:17:18
Protection: AACS2.0/C v76
Data capacity: 89.95 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
I still get errors when trying to Rip a blu-ray disk. Here is a summary:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
Any suggestions on how to get past this? thanks.
Re: SDFtool Flasher
likly a power issue use both usb cable direct to motherboard or get a 35+ watt powered usb hub
Ekontos
Re: SDFtool Flasher
Post by Ekontos »
I am using both cables into USB ports
Re: SDFtool Flasher
Ekontos wrote: Fri Nov 15, 2024 4:29 pm I am using both cables into USB ports
Then option 2 is what you want to go for.
esaus_antagonist
Re: SDFtool Flasher
Post by esaus_antagonist »
Was able to create a firmware backup and flash a LG WH16NS40 from 1.05 (encrypted) to WH16NS60 1.02MK. Thank you for putting this guide together.
CrashOveride
Re: SDFtool Flasher
Post by CrashOveride »
Hello, for some reason the flasher is crashing on bootup. The drive I'm trying to use is the ASUS BW-16D1X-U. I have MakeMKV installed to the default location and am on Win10 64bit.
MakeMKV report:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: [redacted]
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Highest AACS version: 81
Details log:https://pastebin.com/KapLGmCj
Re: SDFtool Flasher
CrashOveride wrote: Fri Nov 22, 2024 11:15 pm Hello, for some reason the flasher is crashing on bootup. The drive I'm trying to use is the ASUS BW-16D1X-U. I have MakeMKV installed to the default location and am on Win10 64bit.
MakeMKV report:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Which version of MakeMKV are you using? Is it a fresh install? If so, you may need to insert a standard blu-ray disc first and open it in MakeMKV so that the latest SDF can be downloaded.
Also, your drive is not one of the common models so the GUI may not work with it. You may have to use the command line instead.
Payti
Re: SDFtool Flasher
Post by Payti »
Hi everybody.
Please help crossflash info for two drives.
1. I have a Pioneer BDR-S09XLT with firmware version 1.54 -> Extra info 20/07/21 PIONEER. Can this be crossflashed to make it UHD friendly?
2. I Have a LG BH16NS40 crosflashed to WH16NS48 firmware 1.D3. Can this be crossflashed to make it UHD friendly?
Many thanks in advance.
Tom
zittrig
Re: SDFtool Flasher
Post by zittrig »
1. Wait for another response. The BDR-S09 should be able for flashing 4k friendly. But another members can help you with this.
2. Flash with the SDF-Flasher to WH16NS60 1.03-MK and after this downgrade to WH16NS60 1.02-MK. This 1.02 ist the recommended one.
Payti
Re: SDFtool Flasher
Post by Payti »
For point 2 I must use this files FW MK:
FW 1.03
\mk-firmware-pack-20200720\MK\HL-DT-ST\WH16NS60\HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin
FW 1.02
\mk-firmware-pack-20200720\MK\old\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
And I should use SDFtool Flasher v1.3.5 ?
Please confirm.
I try flash HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin with SDFtool Flasher v1.3.5 but I have platform error: "The drive you have selected does not have correct drive platform (MT1959) and cannot be flashed"
How may correct this? Or use other flasher eg. makemkvcon64.exe or other tool patched LG?
My drive in MakeMKV presents:
OS device name: G:
Product: BD-RE WH16NS48
Revision: 1.D3
Serial number: K9AE5LAxxxx
Firmware date: 2116-02-04 11:03
Drive platform: MT1939
Firmware version: 1.D3
BD raw metadata read: Partial
THX for help.
Regards,
Tom
Re: SDFtool Flasher
Payti wrote: Sun Nov 24, 2024 6:42 pm For point 2 I must use this files FW MK:
FW 1.03
FW 1.02
Please confirm.
OS device name: G:
Revision: 1.D3
THX for help.
Regards,
Tom
Your LG is the wrong drive platform and should not be flashed. It can't be made to read UHD discs.
Also SDFtool flasher doesn't work for Pioneer drives.
Commo
Re: SDFtool Flasher
Post by Commo »
I am having an issue. I can not get my drive to flash at all.
Here is from MakeMKV:
OS device name: H:
Product: BD-RE WP50NB40
Revision: 1.03
Firmware date: 2121-07-08 16:09
bcm00re
Re: SDFtool Flasher
Post by bcm00re »
Billycar11 wrote: Sun Sep 01, 2024 4:46 pm
Myluckyday wrote: Sun Sep 01, 2024 5:45 am Hello Billycar11,
Here's my LG firmware information from MakeMKV:
Product: BD-RE WH16NS40
Revision: 1.05
Harware support: Yes
Firmware support: No
Firmware version: 1.05
I am trying to flash the firmware using SDFtool Flasher to replace the current firmware version (1.05) on this drive to a new "DE_LG_WH16NS40-NS50_1.02.bin" that I downloaded from this website in the Zipped folder "All You Need Firmware Pack (MartyMcNuts)". Did I miss any step or do anything wrong here? Please kindly advise! Thank you for your time!
See the downgrade flow chart in my guide it does not recommend that fw flash to wh16ns60 1.02mk
I am confused because I follow the Guide link in your signature and the post it took me to says:
Recommended Firmware to flash for MakeMKV:
WH16NS40 on any Firmware directly to > WH16NS60 1.02MK
So I must be missing something...
Re: SDFtool Flasher
bcm00re wrote: Wed Nov 27, 2024 6:35 am
Revision: 1.05
I'm saying the fw he's is trying to flash is wrong he's trying wh16ns40 1.02 de he should be doing wh16ns60 1.02mk
Mr_Orange
Re: SDFtool Flasher
Post by Mr_Orange »
You are talking about two different firmware versions.
The guide says to wh16ns60 1.02mk and you said you were trying to flash wh16ns40-ns50_1.02.bin, which is not the same firmware.
