Updated my firmware. Nice product, works well. HOWEVER, I am still unable to decrypt UHD Blu ray.
Product: BD-RE BP60NB10
Revision: 1.02
Serial number:
Firmware date: 2121-07-08 15:56
Highest AACS version: 76
Firmware version: 1.02
Disc Information
Label: SNATCH
Timestamp: 2021-04-22 18:17:18
Protection: AACS2.0/C v76
Data capacity: 89.95 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
And I get the following errors:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Saved AACS dump file as
Backup failed
Any help?
Can't read AACS VID from disc - most likely current AACS host certificate is drive - Error
Re: Can't read AACS VID from disc - most likely current AACS host certificate is drive - Error
Probably a power issue. Be sure you are using both plugs of the USB y-cable and either use ports directly off the motherboard or get yourself a decent powered USB hub (not one that uses USB power!).Ekontos wrote: Fri Nov 15, 2024 5:14 am Updated my firmware. Nice product, works well. HOWEVER, I am still unable to decrypt UHD Blu ray.
Revision: 1.02
Serial number:
Disc Information
Label: SNATCH
Number of layers: 3
Backup failed
Any help?
